Results 1 to 13 of 13
Thread: Power drain
    Vt Commodore Exec Series II
    Jul 2010
    sunshine coast
    Thumbs down Power drain
    well i been havin a problem with battery drain the last month, im still not sure whats draining it, my question is would the battery light come on if the alternator has a bad voltage regulator? because ive "never" seen the battery light come on when the cars running, so im thinkin the alternator is fine but maybe a bad regulator or a short somewhere???
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    check and clean the terminals on your battery leads. probly pay to change the battery terminals they give problems.
    Making and running DUAL CHIPPED ECU SINCE 2010
    vs commodore
    Oct 2009
    Tamworth NSW
    Check the boot and glovebox light switches to make sure they are turning off the light when the lid is shut.
    96 VS II Acclaim
    Dec 2007
    Quote Originally Posted by Proman View Post
    Yes, the light would come on.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Aftermarket immobilisers can fail and cause a power drain if you've got one fitted. Another thing to check is whether the head unit and amp if fitted are wired correctly to an ignition circuit otherwise they are always on. If the battery is more than 2 or 3 years old then it could simply be old age.
    Jul 2010
    sunshine coast
    Yeah was the head unit hako, thanks
    i bought a test light this morning hooked the clip to the negative battery lead and put the rod to the negative terminal and it lit up fairly bright, so started pulling fuses, sure enough it was the central locking/ Radio fuse doing it, put the fuse back in, disconected the stereo, so i eliminated it being the central locking.... tested with the test light again and doesn't light up now, so who ever had the car before has done some dodgy stereo wiring.
    now the car has enough power to crank, i still wouldnt mind changing the regulator as it only has about 3mm of the brushes left
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can buy just the brushes and solder them to the regulator...costs just a few dollars.
    vs commodore
    Oct 2009
    Tamworth NSW
    Dont some head units use some power (even with the ignition turned off) to keep the radio pre set stations stored,and to run a digital clock if they have one?If so, these would take a long time to run the battery down, wouldnt they?
    Jul 2010
    sunshine coast
    im just going by the test light, there was some some sort of drain something to do with wrong wiring, disconnected the head unit and now she holds charge i dunno its wierd
    1998 vs s3 ute
    Jul 2009
    near blacktown
    check the wire at the back of alternator to if that goes while ur a distance from home dont expect to make it home unless some1 swaps batteries with you and followes you home and swap batteries back like 1 very nice stranger did on the great western highway
    Jul 2010
    sunshine coast
    well that was nice of them to do that, yeah i've redone the wire at the back of the alternator, and cut the battery wires back a bit and redone the clamps as well, cheers
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    In answer to the OP's would the battery light come on if the alternator has a bad voltage regulator?, the answer is yes given if either/both regulator or brushes are on the way out. I speak from experience, limping the car to service with a worn out brush set. I could start the car (3.8L GM V6/1993 vintage), but the battery warning light would come on and periodically extinguish, then return and stay on. I found this very annoying (I was on the perimeter of entering the outback beyond Broken Hill at the time) and making for quite a lot of angst. Phoned home from Wilcannia and a friend communicated with his mechanic: "get a lump of rock and gently tap-tap-tap on the top of the alternator casing". I did this, and found surprisingly I then observed the battery light would go out and stay out for some time. Upon returning to Broken Hill, a techie confirmed it was the brush set and whipped it out and put a new one in: problem fixed! So maybe the regulator on the back is a place to start as a suspect part.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    it says the light in the holden manual means the charging system isn't working, obviously it would just turn on once under a set voltage limit, prob 11volt or so i would think.
  1. hit a drain
    By orch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2010, 10:42 PM
  2. vn power drain
    By vnv6 wagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-02-2010, 10:30 PM
  3. hard to start.. ??? power drain ???
    By scr33ch08 in forum Car Audio
    Last Post: 27-06-2009, 07:55 AM
  4. Huge power drain - spool
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2009, 10:41 PM
  5. help battery drain in 24 hrs
    By red_vb in forum Electrical Wiring / Questions
    Last Post: 16-02-2009, 06:14 PM
