Results 1 to 3 of 3
Thread: VS BCM Issues anyone got any ideas?
    VN S Pac VH SL/X
    Jul 2006
    Default VS BCM Issues anyone got any ideas?
    Hi had some issues with my bcm a while back took it out to get it looked at and now when ive plugged it in again none of the central locking works and the immobiliser is one constantly meaning I cant start the car. Question is when I removed the bcm did I wipe all the information on it regarding the keys? or has the battery in the key died in the process. Cheers
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    sounds like a key issue as you will have to unlock with the key button to disable the alarm/immobilizer, unless some of the wiring is damaged it should work.
    vs commodore
    Oct 2009
    Tamworth NSW
    Maybe you could borrow another BCM thats the same level (low, medium or high)and borrow the ignition key fob from the same car the BCM comes from,and then fit these to your car temporarily to see if it will start.If it does,its either a faulty key fob or BCM.If theres no difference,then check all the wiring connections under the dash.Also check the fuses,fusible links,and try swapping the relays under the bonnet around, also make sure the battery teminals are clean and tight.
  1. Pitching exhaust ideas (custom ideas)
    By JSTCOZ in forum General
    Last Post: 02-10-2010, 06:32 PM
  2. Transmission issues.. Any ideas ??
    By cbb01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2010, 05:01 PM
  3. My 1998 VT Executive, IDEAS IDEAS
    By 98VTExec in forum General Discussion
    Last Post: 22-09-2009, 01:10 PM
  4. vp instrument lights / vp other elec issues.. got any ideas?
    By callum_88 in forum Electrical Wiring / Questions
    Last Post: 22-08-2009, 10:06 PM
  5. VN mod ideas
    By 91VN84km in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-05-2009, 01:24 AM
