Results 1 to 6 of 6
Thread: Ecotec exhaust sucking air. engine missing.
    VS Ute 3.8L V6/M5
    Aug 2009
    Default Ecotec exhaust sucking air. engine missing.
    Ecotec V6 manual Ute, has extractors. engine is missing at all RPM and when you stand 2 ft from the exhaust it seems to be blowing a lot of air, but when you put a piece of paper over the exhaust it guts blown in and out of the exhaust. likely to be an exhaust valve? or could it be an injector? its not an ignition problem cause that sounds completely different. all help appreciated
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    I would be starting on basic things like plugs, leads and coils.
    I doubt the exhaust is blowing (or sucking) any air at all, it should be exhaust coming out of there.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    VS Ute 3.8L V6/M5
    Aug 2009
    No it isn't a lead problem, i've had that before and it makes a completely different exhaust note.
    The exhaust is sucking periodically (once every rev?) and blowing air/exhaust most of the time. so when paper is held over it it vibrates in and out of the exhaust.
    VS Ute 3.8L V6/M5
    Aug 2009
    vs commodore
    Oct 2009
    Tamworth NSW
    Id get the engine compression tested,or buy or borrow a decent quality compression tester and do it yourself.This will show up any valve leakes or other problems.The minimum compression reading for the V6 is 689 KPa or a tad under 100 PSI. The maximum variation between cylinders is 30%.
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    if the piece of paper does look to be sucking in then generally its a valve problem. you can also stick a vacuum gauge on the intake and theres a special way to read it but Ive never done it myself. maybe even do a compression test. test all cylinders dry and write down the readings. then do a wet test, pour a tiny bit of oil into the cylinders. if the readings dont increase then its a valve not sealing. good luck with it
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
  1. ecotec missing under acceleration
    By reegan89 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-05-2010, 05:46 PM
  2. ecotec valley sucking air throw pcv?
    By chris89 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2009, 04:09 PM
  3. Pulled heater controls out - now a strange sucking noise/sucking from pipes?
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2008, 04:01 PM
  4. Engine missing V8 308 VK
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-10-2006, 09:27 PM
  5. engine missing
    By seabass in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 10:07 PM
