Hi Guys . The belt tensioner on my VS seems to be on an angle . The pulley it self is fine but the sprung arm off the bracket is causing the belt to run off centre to the pulley buy a few mil . Is there a bolt that can be adjusted to tighten up the arm or will i have to replace the whole thing ?????
Cheers Mick .
HOLDEN. Not just a car . But a way of life !
It's in the blood and deep in the heart !
Replace the whole thing. For about 120 in total including delivery just get the micro v belt and all the pullys.
if its only tensioner sitting on an angle i would replace just the tensioner..
It's just the tensioner as far as i can see . The spring looks to be pushing it out on that angle .
Cheers Mick .
You will need to drain the coolant and replace the O ring on the heater pipe as well.
Might as well flush the coolant when you replace the tensioner.
agreed might aswell do it one of those maintance things you should do every now and then anyway![]()
How did you get on mate, mine is doing the same. Wanted to know was it easy to get the old one off-new one on ? How much did you pay for a new arm, where from. Did you take coolant pipe off as indicated and replace 'o'ring which 'o' ring??
Appreciate an update
thanks
Did mine last week. $85 for the kit from global which included o rings for the coolant pipes. took 3/4 hr. O rings go on the ends of the 2 pipes you have to remove to get the tensioner out. shocking design.
All went well mate . Yeah about an hour to do .Can pick up the tensioner for approx $90 . I changed the o-rings and the coolant . Their are 2 o-rings .one for the pipe that runs through the tensioner bracket and another at the front that needs to be removed to take the tensioner off . Very simple to do . Hardest part was remembering which way the bloody belt went.
Cheers Mick .
allright guys just got yself a 97 commodore and the tensioner is running on an angle but the bracket does seem to be fine. iwas just wondering after i replace it will the tension for the pulley be correct or is there someway to adjust it? if u have to adjust it how do u do it?
there is no way to adjust the angle of the tensioner. if it is on an angle, the only way to fix it is to replace it as its a one piece unit and spring loaded.
allright i am changing the tensioner now i have mangaged to get the pulley off but not sure on how to remove the spring loaded section. i removed the belt and the tensioner moved up i need some advice please ur help will be muchly appreciated![]()
i managed to pull my finger out and do itjust had a severe dumb moment thnx anyways this thread was helpful
