Ok i have researched as much as i possibly can and cannot figure out the reason why this is happening. i have put a timing light on all of the spark leads to see when the fire and all are correct timing except for cylinder 1 and cylinder 6 (If lucky they will fire mabee 6 times a minute). I have replaced the plugs, leads, coil packs, crank angle sensor, swapped around the injectors, cleaned injectors, new fuel filter and checked the diagnostics for codes and it comes up all good. All the vacuum lines are connected properly too. WTF could be wrong!! any help would be much appreciated
Sorry DFI has also been replaced
