Results 1 to 5 of 5
Thread: Vs gearbox
    VS Commodore Excutive
    Sep 2010
    Cool Vs gearbox
    Hey all got a vs excutive wagon and just need to know filling the gearbox over full mark would it make it delay a second or to to engage when you select reverse or drive.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Overfilling can cause many problems although I don't think what you describe is one of them....however you should drain some out (undo the oil cooler connection at the radiator and let gravity drain some out) It's normal to have a delay of up to 2 seconds before D or R is selected - it even mentions this in the owners handbook so I wouldn't be worried about that.
    vs commodore
    Oct 2009
    Tamworth NSW
    In the VS gregorys workshop manual it says "Do not overfill the auto transmission, or foaming of the transmission fluid,and unsatisfactory operation of the transmission may result"
    Sep 2010
    ok thanks for that where is the oil cooler conection on the radiator thanks.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The oil cooler connections are on the passenger side radiator tank - use 2 spanners to undo as both will be tight....you can get away with just undoing one and then start the engine and run till it pumps out the overfill quantity. Otherwise suck some up the dipstick tube.
  1. wat is my gearbox
    By hombrewvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-08-2009, 05:25 PM
  2. gearbox
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 09:19 AM
  3. I Need A Gearbox
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2007, 11:55 PM
  4. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  5. WTB T-5 V8 gearbox
    By coolngroovy in forum Swap / Wanted to Buy / Trade
    Last Post: 01-10-2006, 12:22 PM
