Results 1 to 8 of 8
Thread: Right headlight not working
    Commodoer VS Executive II V6 3.8L
    Apr 2010
    MELBOURNE
    Exclamation Right headlight not working
    Im guessing its not a fuse or both headlights would not work...something wrong with the connection?...anyone know anything i could try to get it working with my own two???
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Usually just a globe.
    Seperate fuses for LH and RH.
    Just a low beam not working or the whole thing is dead?
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    check fuses...
    then globes BOTH OF THEM
    then switch
    but if your rear park lights work with switch its not switch obviously
    Apr 2010
    MELBOURNE
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    oh god okay do both light on low beam not work?(turn to light on and look)
    are the 2 fuses for low beam in your engine compartment blown? (look through them should see a line)
    pm me if you dont understand any of this fyi
    does your rear no plates and parkers in your tailights work?
    VY SS
    Jun 2006
    Albany
    could be faulty relay, i cant remember if there is a left and right relay but if there is you could just swap them over to check
    Apr 2010
    MELBOURNE
    all the lights work excpet the right headlight, hi beam and parker....ive tried changin fusesss grrrr whats a relay??
    Vr Berlina
    Oct 2010
    Melbourne South East
    had this problem with my 94 Vr berlina wagon.
    it is most probally the relay(s) i ended up buying 2 new relays plus the main headligh fuse.
    be careful as to which fuses/relays you buy.
    goto repco/autobarn and get the direct replacement ones should be bosch(im fair sure)
    as the ones sold at servo's and such and the non dorect replacement relays have different power-pin configurations that will blow other relays and main fuses
    hope that helps if you want i can take pics and send them to you of what i am talking about tomorrow when i get the chance..
  1. one headlight not working on highbeam?
    By nathanVY in forum Electrical Wiring / Questions
    Last Post: 19-01-2010, 10:01 PM
  2. Replies: 2
    Last Post: 07-10-2009, 02:40 PM
  3. Drivers side headlight not working
    By calaiswa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-08-2009, 02:42 PM
  4. traction control light on dash not working... except for the fact that it is working
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2009, 10:41 AM
  5. how much should i pay for a new VS headlight?
    By nickdanger in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2007, 08:42 PM
Tags for this Thread
