Results 1 to 15 of 15
Thread: supercharger pulley
    FG XR6 TURBO /RIP VT II LS1 Clubby, VR Commodore S
    Mar 2009
    Default supercharger pulley
    hey guys ive got a powerdyne supercharger for my vr v6 , i had to order in the " crank pulley " from capa, they said its a universal one, but its only got two location pins ? and the vr harmonic balancer has 3, i rang them they didnt pick up, so is there any way of me putting holes in the harmonic balancer to use it ?
    thanks guys
    going supercharged with comp pacies and 3inch exhuast
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    do not modify your balance shaft.crank shaft
    it is balanced to your car wait until you can reach them they have probably sent the wrong part by mistake...
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    universal theres your issue its up to you to try make it fit your application.the vr standard balancer isnt really able to be attached 2 its not made to be. most likely need to get an aftermarket balancer to mount it on or buy and aftermarket one with the extra pully on it allready
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    Mar 2009
    thanks for the advice guys, ill see if i can get to them tommorow, my cars been off road for a while now im gettin impatient lol
    and if i need a tune ill be pm'ing you delcowizzid
    Mar 2009
    had a talk to capa whom now i will never buy from again, ive been told to put one pin in and drill a hole for the other pin, which is stupid because i was not made aware of this when i was ordering it and then the guy i was speaking to was all like "i don see why its too hard to drill a hole", what a fag the fact that its inconvenient doesnt occur to him, since they dont tell you or supply a manual with the crank pulley
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    damn i wouldnt want to drill anything in that area of my motor not when its balanced already!~
    keep us posted this has my attention!~
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you could maybe get away with an l67 balancer and get it balanced to match the vr balancer will give you the extra pully if it uses that kind of ribbed belt and lines up with the charger
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    thats a very good idea... would save having to buy an expensive balancer
    is the reason you need another balancer due to belt length or just to have an extra set of ribs.... (might sound stupid but wondering if you could get smaller belt...)
    в∞ѕтεכ √&
    Jul 2008
    NZ
    cause it runs on a seperate belt than everything else
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    so an extra set of ribs then cool well that takes easy street out of the gps then!~
    Mar 2009
    i dont think the l67 has that second pulley on the balancer for a second belt to run, coz they run all in the one belt doesnt it ?
    ill have a look into it, and yes ill let you know how the drilling goes mate, i just hope it doesnt stuff up anything since its balanced
    ( btw i sent u a pm delco )
    в∞ѕтεכ √&
    Jul 2008
    NZ
    http://i638.photobucket.com/albums/u...e/PC080283.jpg can get nice aftermarket ones too
    Mar 2009
    thats of a l67 ye, f&%^ should have bought one of those then spending my money on capa
    i don think i can get a refund from capa can i ? dammmmmmmm
    thanks delco
  15. #15
    в∞ѕтεכ √&
    Jul 2008
    NZ
    would just need the balance weight in the rear cut down by the pros to balance it ide say
  1. supercharger pulley
    By dannyn12 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-08-2009, 08:37 PM
  2. Supercharger pulley
    By 6 shooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2009, 07:01 PM
  3. VT supercharger pulley movement...
    By mcgyvah in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2008, 07:54 PM
  4. supercharger pulley
    By harro_VR in forum General
    Last Post: 23-10-2007, 03:19 PM
  5. WTB Supercharger Snout and Pulley
    By VTSick in forum Swap / Wanted to Buy / Trade
    Last Post: 03-01-2007, 01:48 PM
