Results 1 to 12 of 12
Thread: Disabling balance shaft gear? Pros and Cons.
    Home built Charged VS Commodore
    Apr 2010
    New Zealand
    Question Disabling balance shaft gear? Pros and Cons.
    Can anyony tell me about doing this and what it does
    On An Ecotec V6?
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Most people do it so they can fit a double row timing chain. There's no actual benefit from disabling the balance shaft.
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Probably the only benifit i can see is less drive to turn it over. Some people say it creates a slight vibration at about 1700rpm but thats about it.
    Ive taken mine out for my engine build.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    less rotating mass is good for response as well ive taken a few out and yet to feel any difference in vibration in vn-vr
    vs commodore
    Oct 2009
    Tamworth NSW
    Usually if your rebuilding any type of car engine, and you want it to run smooth and hang together better at higher revs,you should always get the pistons,conrods,and crankshaft balanced .So even with the balance shaft removed,with this done,the V6 should run pretty smooth anyway.Some motors vibrate more than others,its to do with their configuration and how many cylinders it has etc.This configuration of engine probably suffers from it at certain revs (as mentioned above "around 1700 rpm") and thats why they run a balance shaft in the first place.
    Apr 2010
    New Zealand
    vp wagger
    May 2008
    woah hang on a second !!!!!! rofl do you actualy remove the balance shaft or just the drive , only asking because if oil runs thru it under pressure if you remove it you loose all pressure thru your engine ? like if you take out the cam etc so if the balance shaft bearing is rattling its ass off you can just pull the shaft out or drop the drive off the front ?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yes there is one oil hole to block on VS onwards either a welsh plug in the hole or or tap the hole and screw in a bung or you can just leave the shaft in there and remove the gear off it
    vp wagger
    May 2008
    Apr 2010
    New Zealand
    So is it worth taking out or will It end in my motor killing itself unless I get it blue printed etc?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    depends if you have the front off and the inlet and doing other work in there you can while youre there it will start rattling at some stage they allways do.if you were just going to rip it to bits just to disable it i wouldnt bother
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    so in my case you you suggest to remove it delco? coz i was contemplating removing it too.
  1. pros and cons
    By SAV_117 in forum The Pub
    Last Post: 29-08-2009, 09:12 PM
  2. LPG - Pros V Cons
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-11-2008, 01:56 PM
  3. Pros and Cons of VY's?
    By 1vngal in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-07-2008, 07:49 PM
  4. WTB: VT-VY L67 balance shaft & cam gear
    By OZ38 in forum Swap / Wanted to Buy / Trade
    Last Post: 16-08-2006, 03:01 PM
  5. What are the pros/cons of a 3.45 VL diff?
    By DavidPartay in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-09-2004, 02:14 PM
