Results 1 to 9 of 9
Thread: Code 76
    Vt Commodore Exec Series II
    Jul 2010
    sunshine coast
    Angry Code 76
    Code 76 is coming on now, something to do with fuel/air ratio left or right right bank, in gregorys manual it sais one of the problems could be exhuast leak, do you think this high pitch rap noise could be related?? the weird thing is the engine light pops on when starting the car for the first time, so i turn the car off then restart the car then the code never appears while driving?? and im pretty sure its not the 02 sensors
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    From memory code 76 is for fuel trim.
    This may be caused by faulty O2 sensors or a bad earth to the sensor.
    Is used to get this until I rewired the earth.
    Im sure there is a how to on this. Might have to try a search.
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    If your getting a variation in air/fuel between left and right banks then it's likely a dead O2 sensor - to check for an exhaust leak first, get your car up on a hoist or ramps and spray some silicon spray around any flanges and welds. You could even take it to an exhaust place to do it, they might not even charge you for the 5mins it'll take to check.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    ^^^^NEVER SPRAY SILICON NEAR EXHAUSTS OR INTAKES!!!!!
    Silicon will destroy the O2 sensors. Even using silicon spray to refit intake ducts is risky.
    This is why 'sensor safe' sealants are made, they contain no silicon.
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    Ummm, how would using silicon spray on the OUTSIDE of the exhaust do ANYTHING detrimental to your O2 sensors?
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Ummmm.........
    Because O2 sensors read the oxygen in the OUTSIDE air through a small passage in the back of the sensor (near where the wires go in) and compares it to the oxygen content of the exhaust.
    How will an EXHAUST leak cause an O2 sensor to FAIL?
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    Quote Originally Posted by RX25SE View Post
    Ummmm.........
    I never said it would you tool. Read the post. I never said anything even like that. I said a air/fuel ratio bank variation could likely be an O2, if it's not an exhaust leak, and to rule out the exhaust leak first....was that really that hard to understand?? I really didn't think so.
    I also said to spray it on flanges and welds, where a leak is more likely - nothing about near O2 sensors.
    If you don't like my suggestions thats fine. Get over it.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by sircruisealotVS View Post
    Perhaps then you could explain how spraying silicon will find a leak?
    vs commodore
    Oct 2009
    Tamworth NSW
    I was thinking the exact same thing.Hows it gonna show where an exhaust leak is?Ive used spray type lubricants (WD40) or dewatering fluid to find vacuum leaks around a leaking inlet manifold,but never heard of it showing up an exhaust leak.With the inlet manifold,the spray gets sucked into any inlet manifold leaks which then causes the revs of the engine to change..I cant see how this will work on the exhaust system though.
  1. error code 12, 3 times then code 76
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2010, 06:36 PM
  2. Code 82 help
    By madmike in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2009, 11:06 AM
  3. Code 42,
    By jakewaze in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-04-2009, 01:36 PM
  4. Code 72 - Vehicle Speed Sensor (VSS) and Code 73 - Pressure Control Solenoid Current
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 04:39 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
