Results 1 to 10 of 10
Thread: big nut thing on steering rack??
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Default big nut thing on steering rack??
    hey i have been haveing a horrible knock in the left side of the car (front) for ages now and changed everything except the rack, but today i decided to check teh rack and it seemed fine but i decided to tighten the big nut looking thing on it near the steering shaft (not the pinion nut the other one thaqt looks complicatied) and it stoped the noise and tighned up me steering (i didnt do it tight as then the steering wheel was very hard to turn)
    wondering what this does and how do i adjust it correctly?
    cheers
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    vs commodore
    Oct 2009
    Tamworth NSW
    It could be the adjustment for the rack to pinion pre load and clearances.If you stuff around with these settings, without knowing exactly what you are doing,the clearances between the rack and the pinion will be set wrong. The steering wheel being harder to turn when this nut is adjusted up,could be the pinion binding with the rack or vice versa,which will wear the rack and pinion out in no time.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Vn Calais
    Apr 2007
    New Zealand
    Like what Brett_jjj was saying, its the rack buffer pad. Adjusting it is fine due to wear, to take up a bit of play in the rack. Dont overdo it, only enough to take the slop out. Is a good indication if you have to adjust it a bit its nearly time for a recon/replacement rack.
    Your talkin to me all wrong, it's the wrong tone. Do it again and I'll stab you in the face with a soldering iron.
    Dec 2009
    If it's the large diameter nut with an "in hex socket" and lock ring around it then it's the steering rack mesh adjustment. It pre loads the rack to the pinion as Brett said.
    To adjust it you need a torque wrench and I think it's called a degree wheel? The correct procedure is to do this adjustment up to a certain torque and then turn the nut a certain amount of degrees. Too tight or too loose and you will damage the rack.
    I once took my VN to Pedders and they did this up so tight the steering would not self centre so I ended up doing it myself.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    chees guys, yeh i did it up tight then backed off a bitt to were it felt non sloppy and yeh it hadles the corners soooooooooooo much better, im not saying its adjusted corectly though which im concerned about but i was thinking of a new rack anyway, but would anyone know the torque settings and dial wheelsettings to adjust this?
    cheers all helpis mch appreciated
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    omg you tightend the mesh adjuster on a modern powersteering rack you never touch it omg new rack coming up
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    lol well it handles a hell of allot better, doesnt have 5 cm ply in the steering wheel any more it actually goes into the direction that i tyurn the steering wheel lmao
    oh well if i need a new rack ill get one but in the mean time i just need the correct adjustment lol
    cheers
    Dec 2009
    Quote Originally Posted by jas98 View Post
    For a VN with power steering the torque setting is 10 to 12 Nm and then you turn it back (undo it) 25 to 30 degrees. I'd assume the VR/VS settings are the same?
  1. VR Steering Rack
    By darkmonk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2012, 01:41 PM
  2. VN to VT steering rack
    By OZLEE555 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-08-2010, 05:11 PM
  3. Swap variable speed steering rack for regular rack?
    By _R_J_K_ in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2010, 08:06 PM
  4. new steering rack?
    By tysonVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-12-2009, 10:25 PM
  5. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
