Results 1 to 2 of 2
Thread: Air con problems
    Vt Commodore Exec Series II
    Jul 2010
    sunshine coast
    Exclamation Air con problems
    i been having a problem with the air con for a while now, when i turn the selector knob it just makes a hissing noise, its like it dont change, like its stuck just blowing air through the front vents, it still get pretty cold but yeah if i put it to a different setting it just hisses and doesnt go away???
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you've been playing under the dash you may have knocked a vacuum hose off - have a look under there with a torch and engine running. The actual vacuum switching unit behind the knob also has a habit of breaking and when this happens it can do just as you describe.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  3. Mod Problems
    By VY 777 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-10-2008, 03:01 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. get going problems
    By SexGod in forum V6 Development And Modification
    Last Post: 23-08-2005, 09:59 PM
