I recently installed my sound system back into my VS and ever since then the battery is being drained, I've jumped and ran the car 3 or 4 separates times after it being drained and it's not stopping, I think the amps are constantly draining power from the battery? Anyone had a similar problem?
this may sound like a stupid question, have you got it wired up properly ?
That's not a stupid question, I'm not surprised if I wired it incorrectly, what could I have wired wrong to make it drain the battery?
Where do you have the remote wire connected to? Thatll be your problem
I did the exact same thing. All it is, is the wiring. I think mine was the deck to the amp, i connected it to the wrong wire from the back of the deck.
the only thing it could be would be the remote wire
or your head unit is f*cked and not picking up the remote wire
All Of The Comments Aboue RE: Remote Wire.. it doesnt take much for some thing little to go wrong
if you want to pump the tunes while ur car is off.
get a capacitor to hold some power
Pulled out the headunit today and the remote wire had came loose, connected it again and the battery hasn't been drained yet, fingers crossed, thanks for all the help!
Well I went out this morning to start my car and the battery was dead again, the amp remote wire is connected properly so what else could it be?
Id be checking that the glovebox light switch hasnt been disturbed somehow when you had the stereo out.It might be stuck and not switching off the light.
where about you located mate? im sure someone who knows what their doing is willing to help you out in person
I'm in the south-eastern suburbs of Melbourne, I appreciate it but I'm sure I can fix it myself, I checked the glove box light before and it was turning off fine, I've re-checked the amp remote wire again and it all looks fine.
I really don't know what else it could be.
Does the power light on the amp turn off when you turn the ignition off?
your battery might have dropped a cell.... how does your car start? does it start the second you turn your key? i had the same prob when i hooked mine up.... might be worth taking to repco, auto barn or supercheap they will do a free test for you it checkes your battery and alternator... worked for me![]()
