Results 1 to 10 of 10
Thread: brake lighting issues
    VS Commodore
    Aug 2009
    Default brake lighting issues
    i have a vs executive and only the interior brake light works, the outside lights dont. every other light on the back works (parkers, reverse, indicators).
    i have checked all the globes and fuses and they seem to be fine, wtf is going on?
    '95 VS Commodore
    Sep 2010
    Frankston, VIC
    VS Commodore
    Aug 2009
    ye mate i checked the fuse and it was fine, swapped it with another fuse (same rating of course) and still nothing
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check the globes, the brake light globes are twin filament, they are also the tail lights. Not uncommon for the brake filament to go and still have tail lights. Also check the holders, sometimes they corrode and don't make a good contact for the earth.
    Visit my Facebook page
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    VS Commodore
    Aug 2009
    so this would occur simutaniously? cause i dont have either side working at all, and it just happended today
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Quote Originally Posted by triple b View Post
    yes its possible they can blow near enough at the same time.
    vs commodore
    Oct 2009
    Tamworth NSW
    Just looking at the wiring diagram in the VS gregorys workshop manual,and it shows the high mounted centre brake light is on the exact same wiring circuit as both the rear brake lights.It has to be a problem with either the bulbs,the wiring or the the wiring connectors..If it was a blown fuse or brake pedal switch playing up,the high mounted brake light wouldnt be working either.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Usually if one fails you don't immediately notice it, but when the second one fails you pretty soon notice it due to no red glow behind when reversing which is probably why you feel they both failed at the same time.
    VS Commodore
    Aug 2009
    yes im feeling really stupid now, it turns out the brake section of the globe was gone on both sides. maybe this occured as i was changing tail lights today.
    thanks for all the input guys and sorry for my stupidity
  1. HELP!!!!!!!!!!!!! brake light issues
    By grn super low exec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2010, 11:58 AM
  2. VP Lamp Issues - My lighting system is fuxored
    By Cogez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2008, 11:20 PM
  3. Brake lights not lighting up when braking
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-03-2007, 08:27 PM
  4. Brake lights lighting at will
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2005, 11:36 AM
  5. VK 3.3 charge / lighting issue part 2 plus EST issues.
    By gs750 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-05-2005, 10:31 PM
