Results 1 to 13 of 13
Thread: auto trans type vs ss s2
    VS SS S2 HSV Enhanced
    Oct 2010
    Deer Park, Victoria.
    Default auto trans type vs ss s2
    can anyone help im in need of a replacement trans for my ss and im unsure with the codes that are related to the trannys which is for a series 2 vs ss is it the 4hbd,the 7hbd or turbo 700 or something else any ideas???
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the VS is fitted with the 4L60e transmission.
    you will need to have a look at the actual trans to see exactly which one you have. as a rough guide 95 model has the 5HDD trans, 96 model has 6HDD trans and 97 has 7HDD trans. if you grab a torch, lift the bonnet and have a look down the side of the bell housing on the passenger side from the top you should be able to see a sticker that has the code on it . the sticker is approx 100mm X 40mm with big black lettering so you should be able to read it.
    it should be either 6HDD or 7HDD depending on the actual date of manufacture of the vehicle
    Body by Holden, Soul by Brock
    the Legend will live forever
    Oct 2010
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The V8 has a slightly different 4L60E trans to the V6 - it has a deep pan and different internal valving plus a different torque converter.
    VX II Calais LS1
    Jan 2010
    #HDD is a V6 trans, #HBD is a V8 trans, 4HBD is a 93/94 VR trans which wont work in a VS it is missing the extra solenoid that the vs requires (VR trans are 12 pin connectors, Vs trans are 13 pin, extra pin for extra solenoid)
    a 7HBD trans is 96/97 VS V8
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    Oct 2010
    i've had a look at the trans but couldn tsee the plate but its build date is april 96 and HSV Enhanced. so would the 7HBD be the right one?
    Oct 2010
    ok according to the ACDelco website a 96 vsII v8 the code is 6HBD but for the HSV VSII the code is 6HSD mine is a HSV enhanced ss and im unable to see the code on my trans confused much?? to add to the problem it only slips from first to second and second to third but it only happens occasionally could it just be the solenoids???
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    just get yours rebuilt as for age of these cars means all second handys will be worn out the bands and clutches will be worn perticluly the second gear clutches
    VX II Calais LS1
    Jan 2010
    7HBD will fit yours, so long as you get a trans with the 13 pin connector you should be all good, (7HBD is 13 pin)
    Oct 2010
    found the stamp on mine its a 5HBD cant afford a rebuild at the moment. Is the case size/length different from a 5HBD to a 7HBD?? could the trans in mine have been a replacement as i thought a 6HBD was meant for my car coz of the year of manufacture??
    1995 vs ss commodore
    Jul 2011
    auckland
    ive just put a new 6hbd in my ss but need to know witch fitting is a feed line and witch is the return line is the top fitting on trans the feed and the bottem fitting on trans the return? some 1 help
    1986 vk wagon 3.3L change to 308
    Jul 2010
    Auckland New Zealand
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    bit late ther camaro. 7 months to late lol
  1. [SA] Wtb: 5l auto trans vn - vs
    By Skidney in forum Swap / Wanted to Buy / Trade
    Last Post: 03-06-2010, 10:42 PM
  2. VS Auto Trans
    By Beno1982 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-05-2010, 05:43 PM
  3. Changing a Vr auto trans to a vn auto trans
    By phildo_mmmk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2010, 11:35 AM
  4. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  5. Auto trans...?
    By MikesVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-03-2007, 05:25 PM
