So in light of the GST hikes we have been going thru over here in NZ, this evening I decided Id try and save a little money and put some diesel in my VS instead of petrol (diesel is $1.16/litre, petrol is $1.80). Seems to run ok, bit smokey though. I was just wondering though, my VS has done almost 400,000 ks and its rings are a bit worn - so I may not have enough compression for the diesel to ignite properly.
My vr is much lower ks though, in better condition and has had the heads shaved a bit so runs higher comp than stock. Do you guys think I would be better running my VR on diesel than my VS? Ive been thinking of asking delcowizid to do a special tune for me to run diesel, maybe once its done you guys could get a diesel memcal and try it too!
no hes fully serious he just left here to go fill up
mix about a liter of lighter fluid in with each tank. octane level will even out and you should be good to go
back in the days of carbies lots of people used to run anywhere upto 50/50 desiel petrol mix with no issues start low on the mix with the injection then work your way up we should fit the wideband and see whats happening and crank in some more timing
I'm not going to do the whole 'you full serious you troll?'
But I don't think this will end well, Diesel and Petrol are not really interchangable or mixable fuels....
Prepare for your motor to die. Very Quickly - unless you undertake some massive work to convert it to a diesel.
How is that even possible? Compression wouldn't even be close would it?
Ronald Reagan (1986)
I was also thinking if I disconnect the thermo fan and put a 103* thermostat in it might burn a bit better too.
And I know its hard to believe guys, but Im not shitting you. I have probably a 70/30 mix of petrol/diesel in the car at the moment - and I intend to bring that up to atleast 50/50 after a few more days.
Ive heard of mixing petrol with diesel (for a diesel engine).It stops the diesel from freezing up in the winter.Never heard of mixing it with petrol for a petrol engine though,keep us up to date on how that goes for ya.
How does the diesel effect running in general, does it use more fuel or sound different?
the old boys used to top up with petrol every fill when doing hauls over the hills gives them a little more punch its like deisel engine booster just if you put too much in they go full throttle with no throttle LOL gets a tad dangerous when you cant stop them reving right out
My dad accidentally put about 10 litres of diesel in his old WB ute and it ran better than it did with just petrol.
None of us are as cruel as All of us. - Anonymous
I recall a ford telstar years ago having a full tank of diesel in it and it would not start lol
