Results 1 to 2 of 2
Thread: Best way to remove oil from cooling system
    VR EXECUTIVE
    Apr 2010
    Tasmania
    Default Best way to remove oil from cooling system
    Hi recentely replaced inlet maifold gasket as had oil in water (gasket was stuffed), ran a flush through for about 20 mins but it didnt clean the oil out, what is best to use to get oil out or should i send it off to the proper place for a flush, cheers Bob.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've used simple dishwasher machine powder or front loader washing machine powder for this - about a tablespoon - and then flush with plenty of water including the heater. The commercial product are basically the same. Don't use hand dishwashing liquid as you'll spend weeks getting rid of the bubbles.
  1. PLEASE HELP!! Cooling system
    By somerton81 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-06-2010, 04:04 PM
  2. Oil in the cooling system
    By vncommy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2009, 06:56 AM
  3. l67 cooling system
    By ashzv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2009, 01:59 PM
  4. Air in cooling system
    By quombone in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-05-2009, 05:45 PM
  5. V6 Cooling System
    By tja_bot in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-03-2007, 01:27 PM
