Results 1 to 5 of 5
Thread: Inlet manifold nut
    VR - EL
    Aug 2010
    WA Rockingham
    Default Inlet manifold nut
    What is the big 17mm nut in the front of the vn,vp,vr manifold a spring is
    underneath it?
    thanks brett
    vs commodore
    Oct 2009
    Tamworth NSW
    It could be the PCV valve.Its under a big nut on some of the V6 manifolds.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    PCV valve is under the spring
    Home built Charged VS Commodore
    Apr 2010
    New Zealand
    vs commodore
    Oct 2009
    Tamworth NSW
    PCV- Positive Crankcase Ventilation.It allows a certain amount of filtered fresh air to circulate through the crankcase of the engine to scavenge any fumes in the crankcase,these fumes etc then go into the inlet manifold where it mixes with the incoming air and is then consumed in the combustion process. .When an engine is running,a certain amount of the combustion gasses escape down past the piston rings into the crankcase,this is known as blow-by.It slowly gets worse as an engine wears out.Years ago before pollution gear was fitted to engines, crankcases were vented straight out to the atmosphere.
  1. Inlet manifold... DOH!
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2011, 04:46 AM
  2. HELP: Inlet manifold
    By ss~skills in forum LSx Development and Modification
    Last Post: 14-08-2010, 03:56 PM
  3. vs inlet manifold
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2008, 12:49 AM
  4. inlet manifold
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 09:52 PM
  5. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
