Results 1 to 5 of 5
Thread: Dash Cluster
    '95 VS Commodore
    Sep 2010
    Frankston, VIC
    Default Dash Cluster
    hey all
    i got a VS commodore now i just got a quick question... do i need different looms if I want to put a digital dash cluster? i have the original standard dash but wouldnt mind putting the one where it tells you how many kms to go and that.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    You can modify your standard loom to suit, its easy enough if you have installed a headunit or two before.
    There is a wiring diagram in the "tripin" thread but some of the wiring colours are different - I wired mine just by the positions on the connectors rather than the colours on the diagram.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    '95 VS Commodore
    Sep 2010
    Frankston, VIC
    Jan 2008
    Just remember to cut fairly long tails on the plugs when you get the dash, you will need them.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    you will have to strip a l3 dash loom to get the necessary wiring and connecting plugs to join to your original loom ....if i had a choice i would take the old loom out pulling a draw wire with it to aid putting it back in, untape between the last dash connector and headlight switch wiring,modify by teeing off necessary wires,retape and reinstall but if you dont care how it looks you can do it to your original loom in the car but its very fiddily.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
LinkBacks (?)
  1. 10-10-2010, 04:53 PM
  1. i need help with dash cluster
    By TY318 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2010, 08:09 PM
  2. vn dash cluster
    By nudge701 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2010, 09:05 AM
  3. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  4. Help With Dash Cluster?
    By vs ss ute in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2005, 07:23 PM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
