Results 1 to 3 of 3
Thread: please help.how do you replace a/c switch in the dash on vs clubsport.
    ve ss commodore
    Jul 2010
    central queensland
    Default please help.how do you replace a/c switch in the dash on vs clubsport.
    please help.how do you replace a/c switch on vs clubsport. do i need to pull the complete dash out? Has there already been a thread on this subject? Thanks
    VS Berlina S2
    Feb 2010
    You will need to pull the plastic instrument surround facia out to gain access to the switch. A few screws then gently pull the surround out as it is also held in by tangs that grip the plastic lugs behind the facia.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check this "how-to" - it includes pulling the switches. Broken Odometer
  1. Replace Ignition Switch and Car Value
    By VL12345 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-01-2010, 10:59 PM
  2. how to remove vx dash to replace headlight switch?
    By one2envy in forum Electrical Wiring / Questions
    Last Post: 13-10-2009, 04:05 PM
  3. replace brake light switch
    By vt16 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-05-2009, 08:21 PM
  4. Power window switch replace (center console)
    By thekow in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-12-2006, 02:14 AM
  5. How to replace Windows Washer Switch?
    By billiejoe in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-05-2005, 12:13 PM
