Results 1 to 17 of 17
Thread: vs commodore problem
    VT Series 1 V6
    Oct 2010
    Australia
    Default vs commodore problem
    i have a holden vs commodore VS II
    today was going for a drive, put the right indercator on its flashing, fast so i got out of the car and had a look and there flashing fast out side, no sure what the problem is, i checked fuse's, hazard lights work, fine not fast, its only when i put the right hand side ones on
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If they flash fast it usually means a bulb has blown, or someone has replaced the bulb with a lower wattage one - check the front,side and rear bulbs on the side they flash fast.
    VT Series 1 V6
    Oct 2010
    Australia
    model is a 1996 , i checked side bulb, and rear bulb are both working, only the side indi and rear indi do, both flash fast dosent look like any are out, i no previous owner replaced them with a crystal bulb or something we have owned the car for a while and havent had any problems, right side only, left are fine
    VS SS
    Aug 2010
    ACT
    James39's Avatar
    James39 is online now Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    VT Series 1 V6
    Oct 2010
    Australia
    i will check in the monring all the bulbs i checked one on side of car(side guard), and behind da car, i will keep u posted guys. ill go check in the morning and replace any if broken if not i will post here
    VT Series 1 V6
    Oct 2010
    Australia
    just checked car than front blinker appears to be out, i poped the hood but was unable to get the blinker light out, any idea how to get these basteds out its tight and has orange plug i cant get out
    vs commodore
    Oct 2009
    Tamworth NSW
    VT Series 1 V6
    Oct 2010
    Australia
    VS SS
    Aug 2010
    ACT
    edit someone already answered while i was typing
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by clee1033 View Post
    any idea on which way they twist, iv tryed both, its bloody tight.
    anticlockwise.
    VT Series 1 V6
    Oct 2010
    Australia
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    If you have the owners handbook you may find instructions (with pictures) in there.
    VT Series 1 V6
    Oct 2010
    Australia
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    so thats left?
    Its anticlockwise or left,when looking at the car from back on.Its clockwise or right if looking from the front of the car.I looked in the gregorys VS workshop manual first up, and it said they turn anticlockwise.When I just went out and looked at mine,thats what I found.You would think the gregorys would have it from the front perspective of the car.Not from the rear,as you stand at the front of the car looking back when doing jobs like this.
  16. #16
    James39's Avatar
    Jul 2009
    Newcastle NSW
    nah i dont, car dident come with anything, which was a down side
    Might find one at wreckers.
  17. #17
    VT Series 1 V6
    Oct 2010
    Australia
    thanks everyone for ya help, new bulb is in and she is running fine, was going to replace the other side but its a tight fit, this bulb was that old the paint on the bulb was so pealing and cracked, and glass was so easy breakable
  1. Problem with '88 vn commodore
    By 1MADVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2010, 01:14 PM
  2. VB Commodore Problem
    By mainpath in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-05-2010, 05:56 PM
  3. Vx commodore problem
    By Rellie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-03-2010, 07:20 PM
  4. Vt commodore problem
    By joshbvnt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-01-2010, 06:15 PM
  5. commodore problem
    By iceknight in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2009, 04:08 PM
