Results 1 to 5 of 5
Thread: diff question
    94 vr HSV gts 6speed 5.7stroker 215kw
    Jun 2009
    no where
    Question diff question
    would there be someone out there that could possibly give me answer,can i replace my diff head for a lsd with a standard diff ratio which i think is 3:08,i am running a 6speed box with a hydratrac with a 3.45:1 want to replace it?
    90 mazda 323
    Oct 2010
    perth nor and lovin it
    Jun 2009
    no where
    it makes a loud wine when you take off in first gear,i presume its the diff
    vs executive s1/ vz berlina
    Mar 2008
    Is there any noise before you put the lsd? if not, chances are you did not put correctly ( clearance between the crown and pinion called backlash) or did you put new bearing on lsd carrier or did the lsd been reconditioned?
    90 mazda 323
    Oct 2010
    if u got irs then the noise might be your rear cv joints
  1. another diff question
    By rob drag racer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2009, 02:13 PM
  2. a diff question
    By POVRTY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2009, 05:17 AM
  3. question about diff gears in a irs diff vs 5.0l
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2008, 04:21 PM
  4. diff question
    By Burnout_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-10-2007, 10:12 PM
  5. VP Diff Question
    By ozzieboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-11-2006, 02:51 AM
