Results 1 to 10 of 10
Thread: Loud knocking noise while car idles!
    ttkepu is offline tkepsCALAISvr
    VR CALAIS
    Oct 2010
    Default Loud knocking noise while car idles!
    Hey, I have a 94 VR Calais and when I start it, it has a 'annoying', loud knocking noise that cycles round and round if that makes sense. Never had this trouble before. Any ideas what it could be?
    Cheers,
    ttk
    90 mazda 323
    Oct 2010
    perth nor and lovin it
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Harmonic balancer?
    +1 for more info.
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    Listen to all the pullys on the front of the engine, i would be going with a bearing somewhere. My tensioners bearing makes a tapping sound every so often.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Could also be a shot engine mount allowing the engine/exhaust to make contact with the body. I'd try and rock the engine by hand to see if it has any side to side movement, also have the bonnet up whilst someone else starts the engine so you can locate the exact source of the knock. Also critical is the frequency of this knock - the harmonic balancer rotates at ~700rpm or over 10 times a second.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    I had a knocking noise at idle too, couldnt figure out what it was till i put the aircon on and it went away. Turns out I have crap in my AC clutch.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VR CALAIS
    Oct 2010
    its coming under the bonnet. Im thinking its something in the engine. Don't know much bout it though
    Kurtp's Avatar
    Aug 2009
    Pakkey VIC
    Quote Originally Posted by ttkepu View Post
    I feel bad, but this reply just makes me lol.
    Open the bonnet and try identify where on the engine it is coming from, find a picture on google and circle it using paint then attach it to this post =]/
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    could be power steering pump on its way out. My VS made a similar noise until i replaced that pump. check it for leaks too.
    James39's Avatar
    James39 is online now Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by Vee-ard View Post
    Some problem with my VR, but has improved with use lol
  1. loud knocking noise from vk
    By phatvc in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-09-2010, 12:34 PM
  2. Loud knocking noise from VP
    By baldy2004 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-12-2007, 10:27 AM
  3. Please help, my vn is in trouble, really loud knocking noise
    By vks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2006, 04:08 PM
  4. Loud Knocking noise
    By VScom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2006, 03:19 PM
  5. Loud Knocking Noise
    By dumpd6 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-03-2004, 09:56 PM
