Results 1 to 5 of 5
Thread: surgeing problem on a VS Equipe
    vk executive
    Apr 2005
    Default surgeing problem on a VS Equipe
    ok 1995 VS equipe ,we drive for 20-30ks then the engine revs fluctuate,very annoying in traffic when parked on restarting the (new )starter moter turns as if the battery is dead or on the way out .Leave the car for say 30 minutes all good.Would this point to a battery cable breakdown or what? thanks in anticipation
    John
    '95 VS Commodore
    Sep 2010
    Frankston, VIC
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe the battery is on it's last legs...or the terminals are dirty/corroded. Another thing to check is the main cable that goes from the alternator to the battery (the fat one at the alt) - these are known to overheat where they join the alt and the cable crytallises internally leading to eventual failure...I would check this item. Problems like this do not fix themselves - usually they fail completely on a dark wet night in unknown territory so if it was me, I'd investigate and repair asap.
    So, inspect the battery cables - if they are not spotless or are not tight then fix. If the battery is more than 2 years old replace it. Batteries are cheap and a tow home will cost much more than a new battery and are one of the major causes of breakdowns. Report back.
    vk executive
    Apr 2005
    Quote Originally Posted by michael.vandervloet View Post
    have you checked/replaced your fuel filter??
    sorry car is running on gas
    vk executive
    Apr 2005
    Quote Originally Posted by hako View Post
    thanks for this ,checked the leads All good so tomorrow new battery (heavy duty )lets hope that works
  1. VS Commodore equipe boot seal problem
    By danielj_au99 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2010, 06:58 PM
  2. VX Equipe II Aircon Problem...
    By Mitch_B in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-07-2010, 07:03 PM
  3. VR V6 Equipe
    By mish2202 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2010, 09:59 AM
  4. VR V6 Equipe
    Last Post: 09-01-2010, 04:15 PM
  5. VR V6 Equipe
    Last Post: 08-01-2010, 01:45 PM
