Results 1 to 10 of 10
Thread: Where to buy aftermarket VS door actuators in Brisbane?
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Default Where to buy aftermarket VS door actuators in Brisbane?
    Hi all,
    Where do I buy aftermarket VS door actuators in brisbane?
    I`ve only tried REPCO so far.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    you can fit standard universal aftermarket one in.
    just need to modify the wiring, and possibly the linkage, but its been awhile since I've done one.
    VX SS
    Jun 2005
    Just buy a set of them at JB or Strathfield car radios (or the equivalent). How many are you needing, I might have one or two genuine or aftermarket ones.
    VS_Pete_1's Avatar
    Dec 2007
    Thanks guys.
    tezza 2 for the back doors how much?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    G'DaY Peter, Just my opinion, but I wouldn't go for aftermarket clamp in solenoid/actuators for 2 reasons: first is they are difficult to fit securely in the rear door with the snib a long way from the lock and secondly they are not waterproof and once water gets in them they fail.
    Have you tried to get the old ones going? ---WD40 etc....they rarely fail in a terminal fashion
    VS_Pete_1's Avatar
    Dec 2007
    not yet hako I think it just needs a clean.
    I think the rain has got to it.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Yup - we're wet up here in the clouds as well. I fitted 4 X aftermarket actuators to my daughters Laser - they lasted 12 months till the rubber boots fell apart and water got in. The factory ones are much beteer designed so I'd go the WD40 route first and save $$$$. Good Luck.
    VX SS
    Jun 2005
    Im sure Ive fitted aftermarket acuators to the rear door of a VS wagon and it bolted up fine to the existing holes. Just had to change the wiring.
    I would definately go genuine items on my car though.
    VS_Pete_1's Avatar
    Dec 2007
    If u can get them.
    Rain i think
    worked to day didn`t worked this avro
    VS_Pete_1's Avatar
    Dec 2007
    After abit of sunshine the actuator has dried out and is working ok.
  1. Vy back door actuators
    By TODDWOOLLEY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-04-2010, 02:39 PM
  2. VQ central locking actuators
    By Shtato in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-12-2009, 05:28 PM
  3. VR/VS Central Locking Actuators
    By Riff88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-08-2008, 11:22 AM
  4. door lock actuators.
    By roy royson in forum Electrical Wiring / Questions
    Last Post: 03-02-2007, 03:04 PM
  5. actuators?
    By `daj0pe in forum Electrical Wiring / Questions
    Last Post: 28-04-2006, 10:00 AM
