Results 1 to 6 of 6
Thread: Rear doors on VS do not lock
    VS Vacationer
    May 2010
    Exclamation Rear doors on VS do not lock
    The rear doors on my VS will not lock either when I use the key fob button or the key itself in the driver door. They will open either way but will just not lock.
    When I attempt to lock the car the front doors are fine but the rear door pegs just jolt a little and stay in the 'open' position. There is a 'locking' sound underneath the panel, but it doesn't actually do anything.
    Please help.
    Thanks.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Unless the snibs (pegs) are loose, I think you are going to need to remove the door trims to inspect the linkage from the door lock to the snib. It seems unusual for both to go at the same time.
    What happens when you lift the rear drivers door snib (with doors locked)?
    vs commodore
    Oct 2009
    Tamworth NSW
    When I first got my vs,both rear doors wouldnt lock/unlock with the remote or when locked/unlocked by the key at the drivers door.You could still manually lock/unlock them with the snipper buttons though.I removed the door trim,and the electrical connectors for the locks had come unplugged in both doors.I reconnected them,and taped them with electrical tape so it didnt happen again.I later read on here that it is a fairly common problem for these plugs to come apart in the rear doors.I read on here that some people have drilled holes through the plastic plugs and wired them so they cant come apart again.
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    i have the same problem but its only happening to the BRH if you lock the doors when you get in and unlock the BRH door manually they all open up so i dont no :S
    James39's Avatar
    James39 is online now Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    One of my back doors would not lock or unlock, it turned out the plug came off the connection in that door.
    1992 VP Executive
    Jul 2009
    Had a similar problem on my VP.
    Try adjusting the position of the CL motors and check the control rods travel the required distance to and from the snibs
  1. VZ SV6. All doors lock when I get into my car.
    By DonB in forum General Discussion
    Last Post: 07-03-2010, 02:00 PM
  2. FS [VIC]: VS stato rear doors w/ door trims, VS 'S' Ute complete doors and VS Seats
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 28-08-2008, 07:04 PM
  3. all doors unlock but only fronts lock
    By LUMPY 8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-07-2008, 08:12 PM
  4. horn always beeps when doors lock
    By rjt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-09-2007, 10:45 PM
  5. How can I trigger the doors to lock/unlock?
    By shaggerz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2005, 12:57 PM
Tags for this Thread
