Results 1 to 4 of 4
Thread: vs 96 Stalling in reverse
    VT Series 1 V6
    Oct 2010
    Australia
    Default vs 96 Stalling in reverse
    Ok i just noticed sometimes when we drive and say we are going to park or when we reverse out of a drive way when we go to stick the car back into drive, the car will stall, and i will have to put it into park and start car again, only dose it when going from reverse to drive, not sure what the problem will be is it common in a vs 1996 series II
    vs commodore
    Oct 2009
    Tamworth NSW
    First up,try checking for any logged error codes.This test can tell you if anything is wrong with any of the engine or transmission sensors or any of the engine management systems.Heres a link that shows you how to do this test.Its quick and easy to do.---Checking error codes VR/VS (Revised)---If you scroll down near the bottom of the posts in this link,theres also some excellent pictures that show you how to do this test.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    also, give the throttle body a clean, especially the IAC valve.
    seems to happen a bit with them.
    VS II
    Aug 2010
    IAC Valve controls engine idle, and is used to raise the rpm (rev's) of the motor when you change between gears. Over time the IAC valve becomes clogged up and sticky, meaning it does not function correctly. The best thing to do is remove the IAC valve and give it a clean, best to do the rest of the throttle body whilst you are at it.
    The IAC valve is part of the throttle body, remove the engine cover and you will see where the air intake tube goes into the throttle body. You can do a search on here for more information.
    Drew
  1. VS Is stalling from reverse to drive?? Help
    By mr_kreative in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2010, 03:31 PM
  2. VR auto stalling in reverse
    By nathg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2008, 06:58 PM
  3. Stalling (auto V6) when changing from reverse to drive. Help!
    By pugga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2008, 07:32 PM
  4. Is this normal? Reverse Stalling
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-06-2005, 11:15 PM
  5. Reverse Stalling in VR
    By RVN 355 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2005, 09:43 PM
