Results 1 to 7 of 7
Thread: supercharged six info
    1996 VS acclaim, L67 VX Berlina
    Aug 2010
    Waikerie
    Question supercharged six info
    im looking to get a bit more power out ov my 3.8ltr ecotec in my vs. was looking and getting a standard superhcarger from a vt along wit heads, wireing loom, injectors ect. i was just wondering how much more power i would get is it worth it or just a waist of money that could be spent on other mods.
    VS S2 Berlina
    Jan 2009
    Stock chargers if im correct only had about 15% increase in power. I don't know how they effected 0-100 compared to a N/A but the charged versions ive seen certainly are not worth bragging about. If you get one look into a higher boost pulley (smaller diameter)
    Home built Charged VS Commodore
    Apr 2010
    New Zealand
    If your wanting to supercharge then try get the complete motor not just the top half (Id say better to keep them as a unit) and then you allways have a running motor in the shed, But as said above you prob wont be that happy with the gain unless you do a bit of work like pully size for boost and headers and intake and make sure to get a good tune and not a (off the shelf) job.
    VS L67
    Sep 2007
    BrisVagus
    The top end swap can be done, but in the long run it will cost you more than getting an complete engine.
    You can pick up L67's (supercharged six) anywhere from 1500 to $2500.
    Look at it this way, your N/A 3.8 produces Maximum power: 147 kW @ 5200 RPM Maximum torque: 304 Nm @ 3600 RPM.
    The VT L67 produces Maximum power: 171 kW @ 5200 RPM (on PULP (Premium Unleaded) Maximum torque: 375 Nm @ 3000 RPM (on PULP)).
    To gain that amount of power and torque from your existing engine, it will cost you far more that the cost of the transplant.
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    cheaper to import twin turbo setup from the states
    Making and running DUAL CHIPPED ECU SINCE 2010
    Aug 2010
    Waikerie
    cheers ppl!! big help still got a bit to think about. but pree sure im keen on a L67, cheap easy power
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    If your interested in a complete L67 conversion send me a PM. I've got one for sale at the moment
  1. Excellent Info on REbuild for L36 or L67 Great info...
    By vxcalais_01 in forum V6 Development And Modification
    Last Post: 22-05-2010, 12:26 PM
  2. differences between vs supercharged and non supercharged engine harnesses
    By jwk87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2010, 07:39 PM
  3. VX calais supercharged info plz
    By mick-888 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2008, 09:57 AM
  4. VK Info
    By Vk_Calais_EFI in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-10-2005, 09:11 AM
  5. Supercharged V6 info
    By jamesfrosty in forum V6 Development And Modification
    Last Post: 24-07-2005, 11:21 AM
