Results 1 to 6 of 6
Thread: VS V6 L67 conversion.
    VS Commodore
    Aug 2010
    W.A. Perth S.O.R.
    Question VS V6 L67 conversion.
    I have a decent N/A V6 and im thinking of swapping it with a more exciting engine.
    Several combinations come to mind, but for the sheer ease, i ahev thought about the L67.
    If i get my hands on a L67 from a VS would i need to change anything other than the engine and control unit, or do i have to change gearbox and harness aswell?
    I have searched the forum, but couldnt find an answer to this question.
    RazzaCaine is offline Long Gone Now
    Mar 2010
    go to www.l67torque.com • Index page and you will find every scrap of information on the l67 and dropping one into any commodore you want that you could possibly ask for
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    As above, the L67 Torque forum will give you all you need to know. But basically, if the L67 is from a VS, all that you will need to change is the complete motor and accessories, the engine harness (or modify your existing one due to different sensor loacations), the pcm (computer behind passenger kick panel) and the fuel pump. The standard ecotec pump will run fine up until the higher rev range when it cant keep up and can result in dangerously lean mixtures. L67's also run a taller torque converter.
    Aug 2008
    NSW South Coast
    Also, you can run a later model L67 in a VS. You will just need to add a coolant temp sender like you do when running a late model ecotec in a VS.
    I have a complete VT L67 conversion for sale at the moment too. PM me for details if you're interested.
    VT exec
    Sep 2010
    South Australia
    Default V6 SUPERCHARGED engine question
    hey, i have a supercharged s pack sitting it the shed, the motor has a loud knocking, i want to know if i can get a standard v6 from a vt and bolt all my supercharger parts over and put it in my car.
    this will include heads, charger pulleys and all. does the l67 have a stronger or different bottom end?
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Quote Originally Posted by aectk View Post
    You can, although the L67 bottom end has lower compression then the ecotec bottom end. Most people would advise against it, better off in the long run getting the L67 bottom end fixed.
  1. L67 conversion OR 5L conversion in vs commy??
    By triple b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2010, 11:54 PM
  2. electric window conversion successful next climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 06:22 PM
  3. Vs dash conversion - Firewall - ecotech swap - vs stato front end conversion
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2010, 10:51 PM
  4. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
