Results 1 to 11 of 11
Thread: Whine from front of VS Executive
    VS Commodore Executive S2
    Jun 2010
    Default Whine from front of VS Executive
    Hi guys,
    Had my transmission serviced a month or so ago. No probs. Past couple of days car has developed a whine which sounds like it's coming through the dash. Whine increases in pitch under acceleration from takeoff and decreases in pitch under deceleration to stop. Cannot hear it at higher revs.
    I am guessing it is something to do with the transmission?
    Any ideas?
    VR Berlina
    Nov 2009
    west suburbs, melb
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    you might have to be more specific than 'whine'. If its a sucking whistling noise it could be a vacuum leak on the intake, or a bearing noise could be an idler pulley getting noisy.
    Any more info ? check the trans fluid level just to be sure.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try it with and without the A/C on - see if the noise goes away.
    Jun 2010
    OK, checked transmission fluid = all good
    Checked A/C on/off = makes no difference
    In terms of the sound... it may be a whirring sound I suppose? Most of the bits which spin on the front of the engine (alternator, water pump, idler pulley etc) have been changed this year.
    I suppose it could be a vaccum leak but it does sound more whirring/whining than sucking.
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sounds like it could be the power steering pump. Very common on the VS.
    Visit my Facebook page
    Jun 2010
    Steering wheel straight or turned doesn't seem to effect it...
    So if it is the pump on it's way out am I right to drive it until the pump gives up completely?
    1997 Vs Commodore Executive
    Oct 2010
    Bundaberg
    Dude try changing the belt, sometimes when the belt go's hard they start to scream, it it dosn't help take it to a pro see what they say.
    Oct 2010
    Bundaberg
    Also maybe just check the water pump, if the pully face can wobble a bit that means it is on its way out. If you look at the water pump face while car is running you will be able to see if it is rotating straight or not.
    Jun 2010
    Brand new belt fitted about 4-5 weeks ago.
    Water pump changed in January.
    Any chance it's the alternator diode? Alternator was changed in about May/June but recon unit fitted not brand new.
    vs ss
    Aug 2010
    nz
    I have exactly the same issue and haven't found the source yet either. Sound coming from behind dash more prominent at high rpm in 2nd for me.
LinkBacks (?)
  1. Red VX Executive - VZ Monaro Front end project
    By pepstar87 in forum VT - VX - VU - WH - V2
    Last Post: 24-10-2010, 09:28 PM
  2. fitting VT front end to a VY executive
    By vy_commy31 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-08-2010, 06:54 PM
  3. executive too ss front bumper
    By lukeyyy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-12-2009, 07:19 PM
  4. VZ SS Front Bumper on a Executive
    By RichoVZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-03-2009, 07:15 PM
  5. vx calais front on vt executive?
    By 666vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2008, 03:58 PM
