Results 1 to 4 of 4
Thread: Vehicle Speed Sensor Fault - Eclipse Wagon V6 ('95)
    VR Eclipse Wagon
    Nov 2009
    Default Vehicle Speed Sensor Fault - Eclipse Wagon V6 ('95)
    Hi yall,
    My wagon has started to show song signs of problems, and the check engine light has now started to glow.
    I checked the the system to find out what the problem may be (bridging pins 5 & 6 under steering wheel), and the code it popped up was '24' (i.e. Vehicle Speed Sensor Fault - VR Computer V6 Fault Codes)
    What does this mean, and what is the best way to fix it?
    Any help welcome
    Cheers!
    vs commodore
    Oct 2009
    Tamworth NSW
    First up,Id disconnect the negetive battery terminal for a minute or two to clear the error code,then recheck to see if it returns after driving the car for a good half hour.Sometimes these errors can set for no reason or from a one off "glitch".If the error code returns,then I'd be checking the speed sensor wiring and connectors.Make sure they are clean and tight.The speed sensor is located on the right side rear of the transmission,(auto). If the wiring and connectors prove to be fine,then replace the sensor.They can wear out or fail just like any other part.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    No useful input here, just curious...what's an eclipse wagon?
    VR Eclipse Wagon
    Nov 2009
    It was apparently a special model when it came out, dont know too much about it, it was my parents car, and passed on to me
  1. Vehicle speed sensor fault
    By MINT96SS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-07-2009, 04:17 PM
  2. Vehicle Speed Sensor
    By JoeNess in forum Electrical Wiring / Questions
    Last Post: 11-05-2008, 09:25 PM
  3. VSS(vehicle speed sensor)how to fix on a VP V8,fault code 24
    By goldvnaero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2006, 09:41 PM
  4. Vehicle Speed sensor
    By MJohns in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-05-2006, 05:22 PM
  5. vehicle speed sensor for vl
    By customcaraudio in forum Electrical Wiring / Questions
    Last Post: 13-01-2005, 10:58 PM
