Results 1 to 4 of 4
Thread: Belt length indicator on tensioner pulley?
    1994 VR Commodore Acclaim
    Oct 2010
    Christchurch, New Zealand
    Default Belt length indicator on tensioner pulley?
    Kia ora from New Zealand.
    I recently bought a VR Commodore Acclaim wagon (the object of all my affection) and I am currently in the process of sussing out what has been done and what needs to be done in the way of servicing.
    Looking in the manual, it talks about the left hand end of the quadrant on the belt length indicator. Now, looking at the tensioner itself, it's not really obvious which end would be called "left", as the indicator is more vertical than horizontal.
    My question is, which way does the belt length indicator arrow travel as the belt stretches/wears? Is it towards the tensioner pulley or away from the tensioner pulley?
    Thanks in advance :-)
    vs commodore
    Oct 2009
    Tamworth NSW
    If you look at the length indicator,theres a line nearer to one end of the scale.It moves toward that.If its on this line or has gone past it into the last section of the indicator,the belt is considered worn out,and should be replaced.Also look for small cracks on the ribbed side of the belt where it goes around the water pump,small cracks showing is also a good indicator that the belt should be replaced.
    Oct 2010
    Quote Originally Posted by Brett_jjj View Post
    - so you're saying that it moves from the outer end of the 3/4 "segment" towards the 1/4 "segment", kind of like a fuel gauge? That's what I thought, thanks for confirming :-D
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by a_kirk View Post
    Yeah thats right.No worries.
  1. belt tensioner throwing belt out of line. HELP!
    By t-rav in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2009, 01:16 PM
  2. Drive belt tensioner pulley question please
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-05-2009, 03:40 PM
  3. Did a silly thing with the Belt Tensioner pulley.
    By menzy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2008, 09:37 PM
  4. Chrome belt tensioner pulley
    By Adza75 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2008, 09:00 PM
  5. replacing bearings on Drive Belt tensioner Pulley
    By turkeychicken in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 01:23 PM
