hi guys ive got a vs V6 5speed manual having a problem with it stalling!
it has happend a about 6 times to me now and isnt very fun when im stuck in the middle of traffic.
when i am driving the engine light randomly comes on then the car just stalls couple of seconds after that
has done it to me doing varing speeds and acceleration
got no idea what it is would appreciate any help
[ENEMY.8]
VS v6 manual (Daily)
HG PREMIER 350 (IN PROGRESS)
VK WAGON 308 (FOR SALE)
hey mate i use to have the same problem in my old vs 5spd. turned out to be my tps (throttle position sensor). so id try first get a second hand throttle body from wreckers. give it a good clean and chuk that in. if that doesnt try maybe a blocked vacuum line running to ur throttle body?
did it again today but would start so i left it for an hour the tryd again it finally went so i rushed home and the poped the bonnet to see there was a split in my sop raditor hose which i think was goin onto my coil packs
so gunna get a hose of my mates vs and try that tonight
[ENEMY.8]
If hot coolant has wet the coils, which are also hot and carrying high voltage, it's quite possible that either one or more of the coils have cracked/split due shorting via coolant or the DFI module has got wet and shorted to earth or whatever. Coolant isn't good with electricity. Hopefully it's still OK.
it did it again today soo im gueess the coils are stuffed from being wet or throttle body sensor or somthing completly different
really cbf with this car atm
[ENEMY.8]
Mate Id do an error code check on it to see if that shows up anything.This test is quick and easy to do,only takes a minute and can save you a lot of time and money by hopefully pointing you in the right direction to what is wrong.---Checking error codes VR/VS (Revised)---If you scroll down near the bottom of the posts in this link,there are some excellent pics and an updated how-to on this test also.
done that check already came up fine which is a pain in the ass
[ENEMY.8]
