I 've just built an Ecotec and I'm using programmable engine management so can set whatever rev limit I like, but at this stage I don't know a lot about Commodores. What's a safe max revs for an Ecotec with standard bottom end.
6500 is on the edge 6000 safe as houses
Really? Only 6500 on the edge ? My Auto took it to 6800 one day, i swear it was going to blow up though lol but only for a moment i guess its ok, holding it at those revs though would die in a matter of moments lol
How about the V8 stock bottom? (rebuilt)
The Daily VN T5V6
355 VN GRP A REP
9000)))
Never mind the bottom end, its the top end of the ecotec that dies at high rpm. after 4500 it valve thrashes badly, (from VN to VR) the engine turns off the knock sensor after 3000 coz it can distinguish knocking from valve thrash, then they jus used better sensors. after 4500 all the torque drops off anyway. it would be faster to shift at 4500 then to let it rev up while it does nothing. i would set mine at 4500 to 5000.
FIRST CAR
'96 VS Executive 3.8L
any fat chicks in the back? that usually causes lack of power and bad fuel economy
The ecotec diden't come out to the vs so was it the same in the eco or just the buick ?
The eco will make power up to wen ever the cam lets it but with the stock bottom end there is no reason it should be revved any more than what the factory limit is set to and holding it on the limiter kiss it as it cuts the fuel and it leans out and as ya know a lean engine goes bang...
I get up to 7000rpm with my ecotec haha. only coz the cams range is up around 6800... not too keen on revving it further tho, dont need to
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
Ronald Reagan (1986)
a good balance job and main studs 7000 is doable lots of guys running up that high but can get reliabuility problems seen some nasty cam damage from revs in the ecotec.ide love to build one for 8000rpm and cam it to suit would make a killer engine if you can get the headflow
ill be doing a buick LOL and it will have a bigger snail than it does now this is why i have forged goodness on order
Your not using the standed fuel cut at that rev are you?
Simple. Get it dyno'd and see where your power drops off. I bet its got nothing over around 5800 depending on whats been done to the motor.
Does the word safe and max rpm even fit in the same sentence? :P
the ecotec came out in all of them, right up to until VZ which changed to the alloytec. The ecotec is a buick. what i meant was that they all valve thrash, it was only VN to VR that turned off the knock sensorThe ecotec diden't come out to the vs so was it the same in the eco or just the buick ?Quote Originally Posted by General Xander View Post
FIRST CAR
This is off the topic but can some one post a reply to this to tell me how to start a new thread? I'm new here and can't find the right button.
What do you mean "whatever section"? Thanks for responding.
Thanks found it eventually. Appreciate your patience....then I misspelled my model designation. I might post it again.
