Results 1 to 3 of 3
Thread: o2 sensors question
    vx
    Aug 2009
    Default o2 sensors question
    do u dis battery or reset ecu after replacing o2 sensors???????
    thanks...
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Not necessary.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    you can reset the ecu by pulling the engine fuse out for 15mins in the engine bay, this will clear the incorrect fuel trims logged in the ecu so it start a fresh, either way it would eventually override all the old values, but i like to start with a clean slate!
  1. O2 Sensors
    By johnvtls1 in forum LSx Development and Modification
    Last Post: 02-10-2008, 09:28 PM
  2. o2 sensors
    By impulsesv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-09-2007, 07:42 PM
  3. O2 sensors are out
    By Z()LTAN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2006, 07:13 AM
  4. v6 and v8 o2 sensors
    By aero19 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2005, 05:37 PM
  5. sensors
    By CAFA_TF in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2005, 09:20 AM
