Results 1 to 4 of 4
Thread: vr blowing greyish smoke
    93 VR Executive Wagon
    Mar 2009
    Melbourne, Bentleigh East
    Default vr blowing greyish smoke
    my 93 vr v6 is starting to puff a bit of smoke on startup after the engine has warmed up- and a little bit when i put my foot down. whats the main cause?
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    How many kays has it done? Worn rings or valves.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Mar 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Unless you are losing coolant (which may suggest an inlet manifold leak which allows coolant into the combustion chambers), I'd first make sure I was using 20W50 oil and not a thinner grade.
    At 180K, it should not be blowing smoke/using oil unless it's done mostly short runs during it's life. Use of a thicker oil will usually reduce smoke, and it's a lot cheaper than doing the engine up.
  1. blowing smoke...using oil..
    By thewaxpigg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-04-2010, 02:33 AM
  2. Rb30 blowing greyish black smoke????
    By callan86vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-11-2009, 01:51 PM
  3. blowing smoke...
    By red_vb in forum General
    Last Post: 19-10-2009, 09:38 PM
  4. blowing smoke
    By mark&sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2007, 06:18 PM
  5. VR Blowing Smoke
    By tr3nt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2005, 10:19 AM
