Hey everyone,
i have recently purchased a VS and now all of a sudden all the elec windows have stopped working all at the same time. I have replaced the relay and the fuse but there is nothing even the little lights on the window buttons are not lighting up. I have been told it may be the powerwindow module on the body or something?? has any1 else had this problem that may be able to help. i'm not much of a guru so lamons terms would be great lol
The BCM (Body Control Module) controls the power windows.Looking at the VS wiring diagram,the power windows and the BCM also use fuse number 7,fuse number 10,and fuse number 23.So check these out as well..
Hey Brett Cheers,
Checked all those fuses they are fine..also swapped the relays and they are all good as well... i guess if it aint the BCM then i got no idea
Maybe a long shot,but try resetting the BCM by disconnecting the battery for a couple of minutes.
