Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: shift kit for auto
    GeorgeB Guest
    Default shift kit for auto
    hey all,
    seriously thinking bout buyin a shift kit for my auto,
    exactly wat is it and wat does it do...
    ive heard too many stories but need to know all the correct details, price and all...
    i got no idea how it works and where bouts it goes..
    so as much info would b appreciated..
    thanks all...
    VY SS
    Aug 2004
    SE Victoria
    about $300. all they usually do is up the pressure so the1-2 shift is firmer. stage 2 they usually put in a new pan and corvette servo and maybe other little things. its about $350 for a stage 2. baywater automatics is a good place. or trickshift in cambelfield (i think).
    cheers.
    CustomVS Guest
    Whiteside automatics do it installed for $350, on Whiteside Rd, Clayton next door to jetspeed and acroos rd from Holdent wreckers.....Shift kits basically changes the lag between gear changes, instead of smoothly changing thus creating longer shifts for smoothness it pushes straight into next gear, you lose smoothness......but run quicker times....
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    VS Acclaim
    Mar 2004
    Melb.
    Quote Originally Posted by AttaBoy
    doesn't it wear out your gears/auto.
    Probably, but that's life. If you want extra performance, stuff wears out faster. That's the trade off you have to live with, depending on your choices.
    I don't like wearing out my shoes, so I just sit down all day.
    Forgive me if I don't reply to a query straight away. The E-mail notification function only works 50% of the time for me.
    VX SS M6
    Jun 2005
    nah it doesnt wear out ur transmission if its a good shift kit it makes the gear changes quicker and harder reducing slipping in the transmission so the cogs dont grind each other while its trying to change gear and it reduces heat in the trans cause the cogs arnt rubbing each other while shifting,
    hard, quick full into gear shifts
    VS II 5 ltr Berlina Wagon
    Apr 2004
    "I don't like wearing out my shoes, so I just sit down all day"
    LOL - gotta use that one day, some where, some day and some how ?
    MY_95_VS's Avatar
    MY_95_VS is offline Drifting Champion...
    VS Berlina V6
    Oct 2004
    Eastern Suburbs, Sydney
    anyone know a good place in sydney to get this sort of work done? I would be interested in stage 2 shift kit for my Berlina VS auto...
    Kinky is using a feather...
    Perverted is using the whole chicken!!!
    VX S Pack L67
    May 2005
    They're a strain on just about the entire driveline and yes they do shorten the live of your transmission. Having said that, It's still a great mod if you're looking to chirp the wheels from first to second, definately not wet road friendly, you'll have the ass kicking out alot. I wouldn't mind one if my transmission wasn't already slipping bad enough.
    VS Berlina
    Jul 2005
    VT HSV Senator Sig 195i A4
    Jul 2004
    Quote Originally Posted by Jollygreengiant
    www.shiftkits.com.au for DIY plus plenty of Q&A's
    That's an electronic shift kit. They are a total waste of time. That will definitely stuff up your gearbox a lot quicker.
    97' VS S-Pack Series 2
    Jul 2005
    Its hard to know what to do...
    50% of ppl say its bad, and the other 50% say its good...
    gettin a bit confused....
    those electronic ones are heeps cheaper, n sound more advanced in technology, but i gotta do some more research, its all gettin too confusing.
    d_neo_b's Avatar
    d_neo_b is offline Tires A-Blazing
    VR Acclaim
    Jul 2005
    Victoria, Geelong
    can somthing like this be done at any transmission place im also lookin to get the stage 2 shift kit
    Jul 2004
    A Hydraulic Stage 2 Shift kit can be fitted by most transmission shop. They should also do a Corvette Servo at the same time.
  15. #15
    VX SS M6
    Jun 2005
    i went to that www.shiftkit.com website and it says this in support area
    Will it damage my transmission ?
    The shift modules will in fact reduce wear and friction within the transmission, therefore your transmission will last longer.
    Shift kits for various transmissions have been around for years, but now with the new range of electronically controlled transmissions, these are the only option.
    is this true??
  16. #16
    VS Executive
    Oct 2005
    could just be a marketing thing are they saying because I would have thought there would be alot more options due to development.
    By dual stage, does that mean stage two? or are they just trying to say daul stge one has two settings.
  17. #17
    2x VS
    Jul 2005
    I've heard that they make the trans last longer, because they lessen the amount of slipping between gear changes, thus makeing your clutches wear less...
    But it also depends how you drive. If you're redlining during gear changes all the time, then I expect it to wear out quicker than normal.
    Disclaimer For The Reader ::
    The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
    If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK
    or do not use the information at all
    I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
    I am NOT a Mechanic. You have been warned.
  18. #18
    StatOmaN's Avatar
    StatOmaN is offline Custom Title
    Vr Statesman
    Aug 2005
    Bangalow
  19. #19
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    yes it does thump a bit even with a stall converter but none nthe less it is better with one
  20. #20
    VS Executive
    Oct 2005
    well by the sounds of things if you can turn it on and off would the thump really bother you because your in control of when it does it and when it stays normal.
  21. #21
    VY SS
    Aug 2004
    SE Victoria
    personally i would avoid a shift kit unless you are going to experience slippage. will the amount you spend on a proper (eg not electronic) shift kit really give you the $300 odd it cost for the kit in less trans ware? i doubt it.
  22. #22
    VR Statesman
    Jan 2004
    Wyee
    I hear they also tear the absolute shit out of the driveshaft centre bearing and can also cause issues like "K" frames wear and tearing.
    Saw this once on my sons VP SS. A real scary site to se the "K" frame tearing like a peice of paper
  23. #23
    spauldj308's Avatar
    spauldj308 is offline S Pack Man
    VR S sedan 5L, VSII ute
    Oct 2005
    Hobart, TAS
    Quote Originally Posted by theburna
    I would say so....
    Im no expert, but yes, Id say they would wear out the driveline more quickly.
    VR II S sedan - Genesis Blue - Cammed 304 - T5 - 19's - Weekend warrior
    VS II S ute - Diablo Red - V6 - Getrag - Daily Hack
  24. #24
    StatOmaN's Avatar
    Vr Statesman
    Aug 2005
    Bangalow
  25. #25
    Vs S2
    Oct 2005
    close to Pt Augusta S.A
    i got told u had to rebuild the transmission when u put a shit kit in is that true?
  1. Shift Light for auto
    By VXIIwagdf in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2010, 10:16 AM
  2. Ls1 Auto Shift Kit
    By VU-S-LS1 in forum LSx Development and Modification
    Last Post: 12-01-2007, 12:03 AM
  3. vn v8 auto stage 2 shift kit
    By griffindore in forum Parts And Other Items For Sale
    Last Post: 03-06-2006, 07:29 PM
  4. vt auto shift kits
    By bordi1983 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2005, 12:49 PM
  5. Vs Auto Shift Kit
    By 64now95 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2005, 07:30 PM
