Results 1 to 7 of 7
Thread: Vs bt1 thirsty!
    97 VS v6
    Oct 2010
    Question Vs bt1 thirsty!
    I have recently bought a vs bt1 and after driving a vt around for a bit i find that its really thirsty, ive checked the plugs and they are clean and the exhaust is the right colour so it seems to be running right.
    Does anybody notice their vs bt1 is thirsty or are even normal vs' thirsty?
    92 VP Series 2
    Jan 2009
    East Brisbane
    i used to own a vs v6 back in the day and it wasnt uncommon to get 11L/100km city driving (that was a 5 speed though) so yer ecotecs are quite good on fuel. your vs should really be a bit better than a vt though because of the little bit less weight............ i'd recommend you change your o2 sensor as a start, its what i recommend to anyone having fuel economy issues, also maybe clean the maf sensor in the air intake, can sometimes make a difference...... anways good luck with it mate
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Get yourself a digital Scale set, sit down and put your right foot on the scale, see how much it weighs then times that by 10, and that's an effective way of measuring your fuel consumption.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you get 300 - 400km from a tank mixed driving then don't worry as it's pretty normal. On long trips cruising at 110 it will go as low as 7.4 L/100km. I think that seeing as it's a BT1 with lower and firmer FE2 suspension, you tend to drive it a bit harder than the garden variety sedans. The gregorys manual shows how to test the O2 sensors - better to check them if you are thinking of replacing them otherwise you are spending $$$$ for no gain. I replaced mine at about 220,000km and noticed a slight improvement around town but it's hard to measure. Critical on VS models is a good radiator with hoses in good condition and running the proper green coolant.
    Welcome to the forum.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    Quote Originally Posted by HamaTime View Post
    lol
    id check error codes first, see if there's anything obvious.
    Checking error codes VR/VS (Revised)
    97 VS v6
    Oct 2010
    Thanks for the feed back guys, its really appreciated. Ill check things out on the weekend as im always busy with it every satdi and sundi.
    I really notice it when i hit the freeway, i can almost see the needle on my fuel gauge go down as my speed goes up, but i do love the car, its enough for me as my first. ill post pics soon
    97 VS v6
    Oct 2010
    Thanks for the feedback guys, ill check it out this weekend and post some pics of it soon
  1. Thirsty VL?
    By eddie would go in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-10-2009, 09:59 PM
  2. Thirsty Thursdays
    By vt1538 in forum The Pub
    Last Post: 27-05-2006, 09:46 PM
  3. My VL is Thirsty
    By CACTUS_13 in forum General
    Last Post: 04-12-2005, 07:32 PM
  4. thirsty for more performance
    By dalip in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-09-2005, 12:54 AM
