Results 1 to 20 of 20
Thread: taking vr 5.0 ltr engine out and need help
    vt calais
    Jan 2010
    Default taking vr 5.0 ltr engine out and need help
    i am wondering how do u take the engine out wth the wiring attached to the moter as i have disconected the plug on passenger side comp and all other conectors but on the drivers side going through fire wall their is no plug it just runns straight into dash.. the engine i am using for my vk conversion so i need the wiring harness to do the conversion.. how do i take the wiring harness do i just cut it where it goes into my fire wall or do i have to feed the whole lot out under dash... let me know as i am not mechanical minded
    vt calais
    Jan 2010
    just had another look and as soon as it goes into the fire wall and through the dash the wiring branches off into a few ways one is to the dash cluster behind some were another into body controll and the other is straight into fuse box near pedals how do you thread through the fire wall im assuming u dont so do i cut it and thread at the fire wall and rejoin the wires ? wen ready to install?
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    nope, take the loom off the motor and unplug the two plugs near the battery.
    vt calais
    Jan 2010
    ok i se that now i can tahe the moter out... but my question is now i need the wiring harness to do the conversion and need the fuse box and wiring harness so it needs to be taken out so im assuming its the under the dash fuses and bonnet ?
    Nov 2008
    Smithton, Tasmania.
    vt calais
    Jan 2010
    Nov 2008
    Smithton, Tasmania.
    vt calais
    Jan 2010
    ok but you know the hole into the fire wall the fuse box and all the other wires wont fit back through as i thought their would be a plug before it went into 100 diff directions but their aint so im stuck on how you are ment to feed it through the fire wall, even if you threaded it from the moter back through the fire wall into the cab you have the other fuse box attached ?
    vt calais
    Jan 2010
    jujibelly's Avatar
    jujibelly is offline ERROR_PATH_NOT_FOUND
    Vr Commodore
    Apr 2009
    Melb
    Mate remove the entire dash and you will understand where
    and how it brances off. You take out the fuse panel and all the rest of the wires thru the firewall hole. Just cut off the ones That you don't need.
    Just a quick note it's a bastard of a job to get the fuse panelout the firewall get someone to help you.
    vt calais
    Jan 2010
    ah ok looks like alot of work is their big issues to just cut the wire before the fire wall and then feed it out or is that creating another problem for me down the track ?
    vt calais
    Jan 2010
    sorrry for the questions but i understand now to take the fuses through fire wall to do the conversion into my vk i am assuming i dont need the entire wiring harness so the bits that go to the blinkers and ignition ect are they the ones i cut as i wont be wiring up the car ill take it some were to get wired and just take the harness were should i be disconecting the harness ?after the fuse box?and after the body controll ? any one know this infomation would help cheers
    Mar 2008
    are you going to be running a bcm in the vk
    im putting a vt 5.0 into my hilux
    i had a memcal done to remove the bcm and security settings
    i dont know about holden motors into another holden as you are doing
    but if you need to get another loom to make it integrate to your vk they come with fuses and relays
    just check it all out before you go cutting anything
    http://www.injectedholdens.com/Wiring%20Looms.htm
    heres some more info you might find helpful
    http://members.westnet.com.au/scottl.../engwiring.htm
    vt calais
    Jan 2010
  15. #15
    vt calais
    Jan 2010
  16. #16
    vt calais
    Jan 2010
    the first website you sent me injected wiring it has no contact on it or any web page were did you find that...
  17. #17
    vt calais
    Jan 2010
    i am currently getting engine ready to get out of car and wiring but im wondering do i need to take everything out like dash blinkers ignition and were ever else it goes into dash ?
  18. #18
    vt calais
    Jan 2010
  19. #19
    Mar 2008
    Quote Originally Posted by dazz9 View Post
    heres the contact for that web page
    injectedholdens.com - Contact Us
    bcm is the body control module
  20. #20
    vt calais
    Jan 2010
    cheers bud
  1. Taking VS Key apart
    By TightAs5 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2010, 09:13 PM
  2. taking out engine wiring loom?
    By ChrisR91 in forum Electrical Wiring / Questions
    Last Post: 08-05-2010, 09:51 AM
  3. taking a engine out
    By homer simpson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2009, 11:47 AM
  4. When taking out my engine
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2008, 09:30 AM
  5. removing sump without taking out the engine - 83 VH
    By -vkhg in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-11-2007, 11:50 AM
