Results 1 to 4 of 4
Thread: VS trans issues
    VK Berlina
    Dec 2009
    Default VS trans issues
    have noticed lately that my statesman seems to change gears in the auto very quickly when not under accelaration.
    eg. accelerate out from a corner & reach around 60-70 & the car seems to change from 2nd or 3rd into overdrive very quick succession.will alsodo this when reaching about 85 even if accelarating.
    this is my 3rd VS & none of the previous ones had issues.
    my question - is this normal ?
    cheers
    92 VP Series 2
    Jan 2009
    East Brisbane
    it really depends on how much throttle your using when it will change gears. have a check of your tranny fluid on flat ground and make sure the level is correct. a slight over-fill can cause shit like that. my vp did the same kinda thing at one stage cos of incorrect level of tranny fluid, particularly when the engine and transmission was still cold. good luck mate
    vs commodore
    Oct 2009
    Tamworth NSW
    Also the TPS(Throttle Position Sensor) when faulty,can cause erratic transmission behaviour.The auto transmission uses signals from the TPS to help control the shifts etc.Also check for any error codes.Heres a link to a page that shows you how to do this.---Checking error codes VR/VS (Revised)---
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check that you haven't inadvertently changed the transmission setting from "economy" to "power" - this will cause similar changes to the shift pattern.
  1. VY ADVENTRA - Trans Issues
    By Cursed CX8 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-01-2011, 08:59 PM
  2. Vs trans pan issues
    By Lance2560 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-10-2010, 12:47 PM
  3. vs automatic trans 'thud' over 80k's + cooling issues
    By SweetWagon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2010, 11:02 PM
  4. auto trans issues
    By VTPREDATOR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-10-2009, 11:40 PM
  5. VX Clubby Auto Trans Issues
    By StealthX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2009, 08:41 PM
