Results 1 to 9 of 9
Thread: headlight problem
    vn calais
    Mar 2007
    epping
    Default headlight problem
    hey got a problem with the headlights not turning off when u open the door after u switch off the car on a vr clubsport. Any idea's?
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    I think you will find it's only cars with a high end BCM (ie. Calais, Statesman, Senator) that turn the headlights off - usually after 90 secs or so. In any case I don't think the headlights will 't turn off if you have the door open.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    You may find the upper level BCMs allow the off time to be programmed. ie. Headlights turn off a short time after getting out of the car.
    The lower level BCMs turn the headlights off as soon as the drivers door is opened with the ignition off.
    Check your dirvers door switch is working correctly. Does the interior light turn on when the door is opened?
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    There is a little switch slightly to the right of the steering wheel. Make sure that is turned all the way anticlockwise and try again.
    Did they used to turn off?
    vn calais
    Mar 2007
    epping
    i had a vr exec and they used to turn off as u opened the door. The door switch is working.
    vn calais
    Mar 2007
    epping
    Quote Originally Posted by RX25SE View Post
    how do u program it?
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    On VR-S Berlina and above:
    Turn on parkers
    Turn on ignition
    Hold dimmer switch in the dim position
    Turn ignition off
    Open drivers door
    Wait desired delay time (max 3mins)
    Release dimmer switch (park lights should go out)
    Not sure if VN-P has this or how to set it.
    vn calais
    Mar 2007
    epping
    vn calais
    Mar 2007
    epping
    nope that didnt work, headlights just stay on
  1. Headlight problem
    By vscommo95 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2010, 05:41 PM
  2. VT headlight problem
    By genaero20 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-07-2009, 08:05 AM
  3. headlight problem
    By v8's rule in forum Electrical Wiring / Questions
    Last Post: 26-03-2009, 12:17 PM
  4. VS headlight problem
    By hoss in forum Electrical Wiring / Questions
    Last Post: 22-04-2005, 09:01 PM
  5. HELP! Headlight Problem
    By moganman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2005, 01:02 AM
