Results 1 to 4 of 4
Thread: heater fan plus
    vs exec 3.8
    Jun 2009
    Default heater fan plus
    V.S. series 2. Hi, heater fan gave up the ghost after working intermittently. Was working fine then just cut in and out. Also the rear window demister ceased to work at the same time and the air con stopped working as well. The hazard lights still work though. I have checked relays and such. Pulled out cd head unit and it went downhill sometime after that but considering this coincidental. Any help would be much appreciated. Normally when there is a problem I find fixes on jc but this ones a head scratcher.
    vs commodore
    Oct 2009
    Tamworth NSW
    Check the blower fusible link which is located down in the small box in front of the fuse box under the bonnet.If this shows to be ok,then check the blower relay located under the bonnet in the fuse box.You can swap this relay for the horn relay or one thats the same ,to test it to see if its causing the problem.Does it work on any other speeds,or just on hi?If you only have the hi fan working,then it will be the fan motor resistor block which is located under the plastic panel under the windscreen.
    vs exec 3.8
    Jun 2009
    Three things do not work at all. Heater fan. rear demister and air conditioner so I an thinking a short somewhere. Have swapped relays and fuses. No joy there. Had a gander at the resisitor, its the solid state type not the element. Not related I say.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I think the "Hi" was as in hello, not HIGH.
  1. Vk heater
    By benjiaka in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-07-2010, 11:31 AM
  2. vh sle heater
    By dan202 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-03-2010, 02:11 PM
  3. heater tap?
    By linz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2009, 12:49 PM
  4. VS Heater Fan
    By VQ Stato in forum Electrical Wiring / Questions
    Last Post: 12-12-2008, 05:58 PM
  5. Heater No Hot Air
    By cuckoo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2005, 04:59 PM
