Results 1 to 5 of 5
Thread: clutch problem
    1994 vr commodore 5ltr V8
    Jul 2010
    blue mountains
    Question clutch problem
    just wondering what is causing me so mych clutch problems i had my clutch replaced i few months ago and when it started feeling different i re adjusted the clutch and just today while driving home i noticed a noice coming from the clutch when not touching the clutch peddle there is a sort of rattling/tingling noise but as soon as i put a little pressure on the peddle or i hold the peddle out a little with my foot the noise stops..
    what could be the cause of this maybe a re adjustment again??
    cheers
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I think there are anti-rattle springs on the throw-out arm that can make that noise. Try doing a search as I've seen this problem before.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by hako View Post
    Are these the ones with the two little rubber buttons on the clutch fork to stop it rattling on the carrier?
    (the ones no one replaces!)
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    The noise that your describing sounds like the throw out/thrust bearing. Usaly there is a spring on the clutch pedal itself to keep presure on it and this usaly stops the noise. Altho damage may already be done to the bearing and still make noise after a new spring.
    Its hard to tell the two apart tho without being there and having heard both noises before. (clutch spring or fork rubbers)
    Good luck trying to replace it in the car!
    Holden do still sell them but dont listen to the idiot women on the phone who dosent know what a clucth is cause they dont care less about you and will just tell you they dont make it anymore.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Jul 2010
    blue mountains
    its only every so often the noise starts it not a constaint noise some days i dont hear it and other days i do so a re adjustment wont help..
  1. vp clutch problem
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2010, 05:32 PM
  2. vk 308 clutch problem
    By vk5ltrm in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-01-2010, 12:47 AM
  3. VS Ute Clutch problem?
    By Leathal11 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2009, 09:46 PM
  4. Clutch problem??
    By AngryVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-09-2007, 06:11 PM
  5. Clutch Problem
    By Andre's SS in forum General
    Last Post: 30-06-2006, 02:48 PM
