Results 1 to 7 of 7
Thread: engine shudder? while i was on 100km/h
    VR Commodore
    Jun 2005
    Default engine shudder? while i was on 100km/h
    hello,
    when i was driving my car on the freeways, there always have shudder when i was floor the acceleration and start shudder while i was overtake or speed up...
    so i have 2 different problem also its going Rich Mixture...
    1) fuel injector, even try put injector cleaner in ... its runs fine then still shudder... maybe some of them is slow flow rate or somethings...
    2) Timing Chain, i think its ways out of the adjustment... didnt touch this .. .. this will make engine go shudder...
    as im still try to work out why thats happen....
    cheers
    VZ SV6, VY SS, 1200 Datto, Triton4X4 , XD Falcon
    Jan 2010
    Toowoomba
    Try the basics first, New spark plugs, possibly plug leads.. Im guessing this is in your VR?
    VR Commodore
    Jun 2005
    yea, its VR v6....
    i just service my car last 2 weeks and had lead and spark plugs change...
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Like Copbaitoz says, plugs and leads first - your problem can occur also due one or more of the coils failing or the DFI module.....but try the plugs and leads first as that is your cheaper option.
    Forget the timing chain as it cannot be adjusted and doesn't sound like injectors. Also try a fault code check which is very easy and only takes a few minutes: Checking error codes VR/VS (Revised)
    1994 Vr Commodore
    Nov 2010
    Hervey bay
    hmmm i've posted in another thread, this sounds like what happened in our 94 Vr today its never really missed a beat but this sounds exactly like the syms we get on power its like this shuddering and its loses power but not all cyls are firing when they should but when you ease off off she goes untill you power.. i sure like to know what this really is....
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Badboy40qld View Post
    Do a codes check first up.... Why they tend to miss when accelerating slightly after cruising at 100kph is probably because the engine is running extremely lean (for efficiency) at cruise, and when just a bit more power is required the engine may miss/hesitate due to the lean mixture - this normally should not happen but coils and the DFI module can leak high voltage etc and cause the miss. But first up, do a codes check.
    1994 Vr Commodore
    Nov 2010
    Hervey bay
    Quote Originally Posted by hako View Post
    only codes that was present something to do with anti theft and oxy sensor but it was not related to the issue, problem solved, issue was on the with the coil pack 3/6 , 2/5 good and 4/1 good but replaced all 3 packs.. it seems to of resolved the small miss at idol to before the the coil pack failed took off 3 and 6 leads the was no arcing... but with the rest there was..
    test drive no shuddering or loss of power..
  1. rough idle, runs rich, engine light, driveline shudder
    By penleja in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2012, 12:25 PM
  2. 25.5L/100km What The F*#!
    By w8stedYouth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2010, 08:36 PM
  3. REPORTING BACK. Shudder at 100km gone.
    By anonymousmoose in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-03-2010, 10:44 AM
  4. engine shudder
    By New2Holden in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-03-2007, 12:29 PM
