Results 1 to 7 of 7
Thread: L67 into a VR
    VR
    Oct 2010
    CRanbourne.VIC
    Default L67 into a VR
    Just wanted to know if it bolts straight in
    or do i have to change some things
    it has an auto trans in the the car (4l60e)
    the car is pretty much 100% stock
    apart from rim interior
    thanks.
    Jay
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VR
    Oct 2010
    CRanbourne.VIC
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    yes it will bolt straight in.
    the problem is the rest of it. ie. wiring, exhaust, rego, engineers cert etc.
    VR
    Oct 2010
    CRanbourne.VIC
    Wamboin23,
    i saw that you have an L67 in your VR
    did you buy it like that or put it in yourself ?
    if so how much $$$ roughly am i looking at
    to get one in mine
    cheers.
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    prob cost somewhere around $3500 to get it in, thats with me doing everything.
    it's the small things that you forget about that add up/
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Probably cheaper just to buy a VS Calais with a L67?
