Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: Possible to extend the key range on central locking?
    Patti2912's Avatar
    Patti2912 is offline P4TT1
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Default Possible to extend the key range on central locking?
    This isn't a major issue, just something i think would be pretty nice if it could be done.
    I'm kinda getting sick of my VR's 1 ish metre range when unlocking it with the button on the key.
    I've noticed that sometimes (more-so on the passenger side) i have to get right up to even within a foot of the car for it to unlock, where as the drivers side goes out to about a metre - a metre and a half.
    This has me thinking that as its aged, whatever it is that picks up the key has lost some functionability.
    My question is, firstly what is this part, and is there a way to increase this range, fix, or replace this part?
    My old VT would unlock up to about 4 metre's away and it would be great to get something like that back again.
    Cost, who does it, whats involved and all of that please!
    Quote Originally Posted by Morton View Post
    You're better off using a 175g can of Masterfoods Wholegrain Mustard. I just measured that, and it's 9.5cm tall. Keep one in your car at all times, and if a police officer tries the "coke can test", you can tell him what I told you
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Quote Originally Posted by The1 View Post
    hold it to your head
    Great reply, thanks!
    >_>
    91 vn s
    Jun 2009
    Adelaide, SA
    Hold it to your head. works on my dads AU, works on my VN. normally the vn ( aftermarket system) is like 30 metres or something ridiculous. if i hold it to my head ( for party tricks ect) i can get over 50-60 metres out of it. no bullshit. lol
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Quote Originally Posted by somefool View Post
    Oh, really?
    I figured the comment before yours was a dig, lol.
    So hold it at head height facing the car, or hold it facing my head? :S
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    how old is the key, getting a new keyhead may help to.
    Pretty sure its quite old man,
    Should i just get a new one cut/made?
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    the key is fine, just the plastic keyhead, you can get a new one done for less than $100 You need to take it to someone that has a scantool to program a blank key to your car, i think also if you goto Mr Minit they can program a new one from your old key.
    There's a cell battery in the keyhead that powers the transmitter for the lock unlock buttons after 5 or so years they can start to die.
    To your other question you point the key towards your head while looking at the car.
    91 vn s
    Jun 2009
    Adelaide, SA
    [QUOTE]Oh, really?
    So hold it at head height facing the car, or hold it facing my head? :S/QUOTE]
    yeah, if the key is old then a new one cant hurt. my mates got a VR, same problem as you. i didnt think of the key-head trick at the time though. give it a shot.
    Um i usually just hold it up to my temple and push the button, wether your facing the car or not shouldnt make much of a difference.
    got the idea off top gear when Clarkson did it on a Lambo :P
    ...hmm i wonder if doing this on a regular basis microwaves your brain... but then again we spend way more time with a mobile phone held up to our head than the key to our cars
    ( sorry i ramble) ha
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Hahaha,
    I was just thinking "...im going to end up with cancer because of this",
    As long as it works though aye?
    Ill test out your theory when i finish work and report back.
    Thanks a heap guys.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Quote Originally Posted by Patti2912 View Post
    Oh, really?
    Hope that helps...
    VS Executive S2
    Aug 2010
    melb
    Oh wow, im gonna try it tonight while walking to my car after work. I'll probably look like a knob doing it....
    BTW, anyone know how it works?
    vs commodore
    Oct 2009
    Tamworth NSW
    I cant see how it would be any different from just holding onto the key with your hand,thats if it uses your body or whatever as a sort of aerial extension.Maybe its just because you are holding it higher up than usual.When these keys are new,they work over a fair distance anyway.Does anyone know where the actual signal is picked up at on the car? I know the BCM receives the keys signal,but you would think it would need some kind of aerial to pick up the signal from the key.So does it use a type or aerial,or does the BCM receive the signal directly from ther key.You would think the BCM would have trouble receiving the signal directly, being up under the dash.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    A new key head should help as the battery is new.
    If you open up the BCM you may find a loop of wire soldered into the board. This is the antenna for the key.
    If you extened the antenna by looping a thin insulated wire (do not solder it) around this antenna and run it out of the BCM and up the drivers door pillar, this also should help the range.
  15. #15
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Geez,
    I tried this walking up to my car last night, about.. 10 ish metres away,
    Unlocked first time!
    I though to my self "no friggen way" and tried to lock and unlock it normally with no luck, then put it back to my head and heard that re assuring 'click' of the locks move again.
    I walked to what must have been 30 metres from my car, and successfully tried it again without any fails.
    Tried it as well on my mates Omega last night and got at least 50 metres away.
    Amazing,
    Thanks guys.
  16. #16
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Geez,
    Amazing,
    Thanks guys.
    There is a side affect, by the age of 50 your brain will be totally diminished :P
  17. #17
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Quote Originally Posted by jokerflingo View Post
    Mobile phones, tap water, microwave ovens, exposed sun light, cigarettes..
    What's one more on the list? :P
  18. #18
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Ok guys, so this is a cool trick but im really needing to figure out a way to extend this range.
    Can i replace or upgrade the antenna or something?
    A friend of mines Sportivo reaches somewhere around 50 metres, and naturally as Commodore owners we like to be the best,
    So lets put our semi fried and tumour ridden brains together and figure this out!
  19. #19
    VL Commodore
    Dec 2008
    I'd say a larger antenna on the car, you'd have to find out what frequency it uses, and then research omni-directional antenna designs that are good for receiving that frequency.
  20. #20
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Um..post #14?
  21. #21
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Quote Originally Posted by Z2TT View Post
    Would this be a BCA antenna or an exterior antenna?
    Thanks mate.
  22. #22
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Quote Originally Posted by RX25SE View Post
    Um..post #14?
    Noted, though figured there may be a slightly more attractive way to do this, as i was asking if i could replace or upgrade the antenna, not have it hanging up out the door, which is what i imagine it would look like.
    If im wrong please correct me as to exactly where to extend the insulated wire to and if it could remain covered.
    Cheers.
  23. #23
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Cheers.
    You would run it out of the BCM under the dash to the door pillar and under the pillar trim.
    It would not be visable at all.
  24. #24
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Ok mate.. im pretty sure i understand, and it seems pretty simple to do.
    Ill look into getting that done and see what kind of improvement it gives,
    Thanks
  25. #25
    VS Series II Supercharged Statesman
    Nov 2010
    Can someone provide a pix of where the BCM is exactly (97 VS Series II SC)?
    My carkeys behave weirdly.
    one has 'across the yard range' while other is 'next to door'.
    I also bought a replacement key so i dont have to keep paying $100+ everytime battery goes flat. (it has next to door range on it now, but has old battery in it)
  1. Extending range of central locking
    By Denno in forum General
    Last Post: 30-03-2009, 06:12 PM
  2. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  3. Central Locking
    By RoboticCherry-Coke in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2008, 01:13 AM
  4. extending the range of central-locking remote?
    By kyle_vovin in forum General Discussion
    Last Post: 10-10-2007, 06:50 AM
  5. Central Locking, Range is Very Short
    By millencolin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2006, 09:02 PM
