Results 1 to 3 of 3
Thread: Inlet heater pipe o ring keeps leaking
    vs calais
    Dec 2008
    Default Inlet heater pipe o ring keeps leaking
    Hope someone can help me out
    I changed the tensioner assemby today and the heater pipe that goes into the side of inlet keeps leaking even though i put a new o ring.
    Is there any trick to this or has anyone had a similar problem
    By the way i put a new oring and used petroleum jelly
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Where'd you get the o ring from? Definately the correct size? i.e it needs to be a snug fit on both the heater pipe and where it fits into the inlet manifold. Using a little petroleum jelly is correct but did you also ensure where the o ring will be seating is thoroughly clean and no corrosion dust ect that could prevent a perfect seal? Even any coolant sludge could do this. How did you insert the heater rod? The best way to do it is to first loosely install the alternator with tensioner attached. Then feed the heater pipe behind the tensioner arm and locate it into the hole in the manifold. Make sure you locate the bracket on the pipe to go over the threaded stud as this will make sure you dont push the pipe too far into the manifold. If you do push it in to far and it pops through, often when you pull it back a bit to where it should be it can dislodge the o ring or tear it a little. Then tighten up the two threaded studs, reconnect your earth wire with the lock nut and also the small 10mm bolt on the alternator top bracket.
    Hope that helps .
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Clean the manifold where the pipe fits in .Use some fine wet and dry and some dish washing lquid to get rid of the build up of scale in the opening then flush it out to get rid of the crap. Use the genuine Holden O ring not a Bunnings one especially if it is the red colored one as the profile is different . I covered the end of the heater pipe and O ring with dish washing liquid before fitting .
  1. [VIC] FS: VE SS Airbox+pipe+ Genuine Holden filter- 4" inlet
    By calaiscruzer in forum Parts And Other Items For Sale
    Last Post: 27-10-2009, 07:42 PM
  2. heater pipe leaking
    By VTPREDATOR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2008, 01:09 PM
  3. Heater pipe o ring
    By tezza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 06:52 PM
  4. Fuel injector leaking around O-ring
    By andy05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-05-2006, 03:57 PM
  5. V6 swallows plastic plug from inlet duct pipe
    By KB3800 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-08-2005, 05:52 PM
