Results 1 to 10 of 10
Thread: VR Commodore, changed alternator but still not charging
    VR
    Oct 2010
    NZ
    Default VR Commodore, changed alternator but still not charging
    I'm lost for ideas, changed alternator and it charged for first 2 starts but nothing after that, surely a 2nd alt hasn't failed?
    Any ideas?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    there is a wire that runs from the alternator to the battery to sense voltage. if this wire is broken it will not charge. at the battery this single wire has it's own connection and plug from memory
    Body by Holden, Soul by Brock
    the Legend will live forever
    VR
    Oct 2010
    NZ
    Hey mate,
    Yeh that wire is hooked up, pulled alt out again and checked everything was good, it's a recon unit so should be fine. Put back in and it's charging off and on now but the sense wire is not broken or dodgy in any way so completely stumped
    The main wire is in new like condition so no corrosion etc..
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Pull out the voltage regulator and make sure they have replaced the bushes properly during the recon.
    darcycammo, this may be the answer for your problem. The bushes wear down over time and need to be replaced. You should be able to replace the voltage regulator without removing the alternator.
    VR
    Oct 2010
    NZ
    Checked all that, it all seems ok.
    If car is not charging when switched on a good hard rev will put the alt light out so I'm confused even more, once it goes out it seems to stay out it's just that sometimes it will stay on unless revved hard if that makes sense.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    To check if it is indeed the brushes in the alternator sticking, simply start the engine and presuming the red light is on, tap the rear of the alternator (and the black reg) with either a soft faced hammer or the handle of a screwdriver - this will usually jar the brushes into contact with the slip rings - then if the red light goes out you know it is the brushes sticking.
    90% of 'reconditioned' alternators simply are fixed and then painted - either brushes or a bearing will have failed and parts involved cost under $10, so a reco alt is generally just a repaired alt.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    if its not turning out the light unless it is revved hard, sounds like it the alternator itself, I'd take it back and get them to test it. could be a regulator problem, or diodes.
    VR
    Oct 2010
    NZ
    Cheers guys, one last question. Is there anyway to test the reg while it's off the alt?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    before checking the reg get a multimeter and check that both wires that plug into the reg have 12v with the key on when unplugged from the alternator white one goes directly to the battery via a fusable link the other brown one goes to the batt light both should have power with ignition on
  1. VE commodore or Pontiac G8 Alternator Whine.
    By matthewo in forum VE Holden Commodore (2006 - ?)
    Last Post: 25-07-2009, 05:47 AM
  2. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  3. Charging problems? wtf? (alternator?)
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2008, 09:08 PM
  4. Black Cable from back of the alternator (96 commodore vacationer)
    By TwistedGecko in forum Electrical Wiring / Questions
    Last Post: 26-01-2008, 12:10 AM
  5. charging
    By Mr Ute in forum Yella Terra
    Last Post: 27-04-2007, 03:29 PM
