Results 1 to 4 of 4
Thread: Bigger master cylinder
    VX SS
    Jun 2005
    Default Bigger master cylinder
    I think my master cylinder needs to be replaced, so instead of replacing it with a 7/8" (?) standard master cylinder, is there any benefits of installing a master cylinder with a 1" bore? Will it bolt up?
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    My vh has stock vp discs/calipers and standard rear vn discs and its booster let go one day(master leaked fluid into the booster)...I replaced it with a vt booster and master as the cost was similar to a new inch stock vh cylinder and now it stops so well with next to no travel so for me it was very worth it .
    If your car has a plastic booster the later model cylinder will bolt up (it is very similar to look at to stock vs but with bigger internals)if you cut the screw off flush with the rod on the booster where it contacts the cylinder or buy the spacer that makes up the difference that goes between the master/booster.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    VL Commodore
    Dec 2008
    VT Booster and Master sounds the go I guess for our VS's, does it bolt up or do quite a few mods need doing?
    Guide here on Calaisturbo forums on putting it onto earlier models - http://www.calaisturbo.com.au/showthread.php?t=134762
    Think some applies for the VS.
    Does it make a difference if you have ABS or not as to how hard the conversion will be? e.g do you have to find a VT with ABS to get master/booster from
    if your VS has ABS? as in are master cylinders on ABS cars internally different?
    As for VS, which ones had the 7/8 and the 1" Master?
  1. VR master cylinder
    By chrisdoesitbetter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2010, 10:21 PM
  2. VN V8 Master Cylinder
    By 8rody in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2010, 05:11 PM
  3. VR ABS Master Cylinder
    By muttley383 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2009, 04:20 PM
  4. strut brace with bigger booster and 1"master
    By VL Berlina 5speed in forum General
    Last Post: 30-09-2008, 08:07 PM
  5. VS master cylinder and ABS Q
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2008, 11:55 PM
